I guess I should learn to keep my nose out of matters of which I have no direct knowledge (e.g., what a 25 exactly looks like inside), as it sometimes gets me into speculative solutions to problems that may or not be the most practical! Also, when you're first to post on a subject, you don't always have the time to evaluate a solution and double think it through. Easier to set back and find the errors of others.
Nonetheless, here are some continuing thoughts on this subject:
1. It's amazing that the freshwater tank would be sealed inside the v-berth compartment. At a minimum, a watertight inspection port would seem to be in order here to be able to check the plumbing connections.
2. It's surprising that the 25 only has a 24 gallon tank, considering that the 22 has 20 gallons, sans shower and head. Is the heater tank typically filled with water as the main tank is topped off which increases the total capacity a bit, say from 24 to 29/30 gallons?
3. It doesn't matter a bit whether you dress up or simply hide the sight level tube, just suit yourself. Or go without the tube and fill up at every opportunity. (Dusty wouldn't like this approach!)
4. I'd much prefer a closed sight tube system system with the vent at the top of the sight tube returning to the intake vent tube for sanitary and safety reasons.
5. The sight tube and it's connections can be of any diameter, since they're not in the supply system, making a 1/4" or so tube set up possible.
6. I'd have to agree with Roger's analysis of Mike's 2-valve hose bridge set up, at least as I understand its proposed construction.
7. Mike- Is your Cruise Ship's set up with the three tanks OEM? If not, how many changes have you made? What is your current capacity? Are the tanks at equivalent heights/levels so a sight tube set up would work, or...?
8. A dockside pressure hose intake would have to have a pressure regulator installed to reduce the pressure to on board pump levels to protect against high pressure blow-outs! To do otherwise, would require doing the entire plumbing with rigid PVC pipe, as in motorhomes, or braided reinforced flexible tubes rated to withstand the pressure. Also, the main tank has to be set up to go off the system and be bypassed (not pressurized). Then there's the issue of needing to increase waste water storage capacity......blah, blah. Way easier to just dangle the water hose in the intake port and turn it on when getting low on the sight tube.
9. An electric level gauge could be OEM installed on the tank, they have specific ones designed for fresh water use for motorhomes.
10. Pat: 24 or more gallons per night, eh? AND you have the water saving composting toilet (no report yet?)! Must be the mini hot tub custom conversion that's sucking up/down all the reserves! Lots of possibilities exist for an incomplete fill up. Might be time for a trip back to the 5 gallon bucket routine to check out the input total.
Youzer! (Sp?)
This whole affair is a great lesson in the KISS Principle! Joe.
