Did you disconnect the gas line? You should, then as it starts to sputter, fog it. Then remove spark plugs and fog inside the cyls and crank it over a little to distribute the oil. Then reinstall the plugs, hand tight.
Good luck. Make sure the fog oil is getting into the air intake.
