Greeetings to all. I had the opportunity to try out my flushing bag to flush the engines with the boat moored in its slip. It's not too tough to do and seemed to work pretty well. With the motors up, I slipped the flush bag (flex water hose pre-attached)around/under the lower unit, then dropped the motor until it pinned the bag in place against the saltwater below. Turned on the hose and allowed the bag to fill to above the Permatrim, which expanded the bag and allowed me to drop the motor further down. Holding the bag by a bungee cord hooked through the grommet, I started the motor with the hose running. Worked perfectly well until I put the motor in gear which tore up the bag (just kidding!!)and I flushed each motor for a couple of minutes. Shut off the motor and raised it up. The bag slipped off and spilled it's fresh water out just as the motor cleared the saltwater. The motors got an excellent flush; better than with muffs. I ordered the large size bag for large outboards/stern drives, and it's plenty big enough to fit around my Honda 40's with Permatrims. I will modify the bag by attaching 4 lengths of 1/4" line at the corners to tie it off while flushing as this will make the process easier. The current Honda 40/50 have a flush port attachment whose design makes it impractical if not impossible to flush while the boat is in the water. Moreover, these motors are susceptible to salt buildup in the thermostat which can cause it to stick open and mess up the motor. The biggest risks with this operation are: 1. slipping while stepping in the splash well or on the transom, and 2. looking like a dork while doing this operation in the marina. With the price of engines these days I think I'm thick-skinned enough to handle the lattter. Best, Mike.
