flush fitting
dotnmarty
Active member
Nov 3, 2003
4,202
2
1993
user_field_choice.c_dory_model_16_Angler
Hull Identification Number
DOR15295C393
LIZZIE II
This may have been covered previously but I can't find it. Is there a fitting on a Honda 40 where I can attach a hose for flushing or must I use the earmuffs? I seem to recall that there was a screw-on hose fitting on the 75 we used to have. Thanks
I'd also be interested for our Honda 45. Also how long are people flushing for? I have a maintenance and repair manual that states 5-10 minutes. I hate to waste that much water if it isn't necessary.
Chris
You might want to try Salt -away every month or so and when you put the boat away in winter for sure .
I think the bigger engines have a hose fitting but not the <50HP ones. My 45's didn't and the 35 I've got now don't. The hose fitting doesn't do a complete flush because you can't run the engine when it's flushing. Only with the muffs or in a tank.
Marty I had the dealer put a flush hose on my Honda 50. He somehow tied into the cooling system under the cowling and ran a hose out where the wiring exited the engine. I had this because of storing my boat on a lift but if I had a choice I would prefer to flush with the muffs and the engine running.
OK guys thanks for the good advice.
My 2009 Honda 50 EFI has a port on the lower end for a hose adapter. I asked my dealer about it as it did not come with the adaptor, but it was shown in the owners' manual. Sportcraft Marine told me the order of preference for flushing went like this: First- A Bucket, Second- Muffs. Last- Hose Fitting.
