tpbrady
- Joined
- Feb 7, 2005
- Messages
- 891
- Reaction score
- 0
- C Dory Year
- 2005
- C Dory Model
- 25 Cruiser
- Vessel Name
- Bidarka II
I took just finished my shakedown cruise of a new CD-22 in spite of 3 foot chop with winds gusting to 20 mph in Passage Canal out of Whittier. We really exercised the trim tabs to minimize the pounding. 18 knots downwind and 11 knots into the wind seemed to be the best spots. I also learned how poor a job the factory did in mounting the the tank and the trim tab switches and the position indicator. The position indicator didn't work, the zero degree light just flashed. The indicator was mounted so low you couldn't see it unless you kneeled down next to the helm. The switches are below the indicator so you have to lean forward to activate them. All and all they are in the wrong place.
The pump was put on the starboard side of the drain plug with the hydraulic lines running straight back toward the cabin. At least the kicker fuel tank still fits. This needs to be moved or at a minimum 90 degree fittings put on the hydraulic lines.
I took a quick look at the back of the indicator panel to see if there were any obvious problems. What I found would have flunked a quality control inspection in middle school. The red and green sensor wires were soldered to addtional wire to send them to what appears to be a control module. Neither of the solder joints were insulated and were probably shorted to one another during most of the trip. What appears to be a ground wire was literally stretched to get to the electrical ground and tight up against the steering box. A similar ground runs from the control module to the electrical ground bus and it is also very tight.
Aside from the trim tabs, the boat ran as anticipated and surprised the salesman. I went with him while he ran a familiarization ride on a 25 foot Jetcraft for a customer. The C-Dory took the chop as well as the Jetcraft but only a couple of knots slower with a lot less water on the windows. The Evinrude 90 E-Tec ran well, consuming 5.1 gals in about 1.5 hours
over a distance of about 18 miles.
Red Fox is in the Sound. I passed him heading toward Whittier just north of the Twenty Mile River.
tpb
tpb
