Well-known member
- Joined
- Nov 2, 2003
- Messages
- 21,793
- Reaction score
- 142
- C Dory Year
- 2007
- C Dory Model
- 25 Cruiser
- Hull Identification Number
- DOR25652A707
- Vessel Name
- thataway
Boat Test.com has done a review of the new G2 Evinrude E Tec. Some very interesting features, including the steering mechanism built into the mount, so no rams in the splash well, or bracket. There is a 81 degree tilt--which will put every motor out of the water. Very low water pickups for shoal running, and a redesigned gear case--less chance of weed/kelp hang up, plus gone back to electrical gear shifting in the lower unit (I had that in the 70''s on an Evinrude) Plus ability to swing a larger prop.
Magneto type of charging system, eliminates alternator belts. 133 amps of charging capacity, and joystick maneuvering with twins, eliminating the necessity for thrusters....
These features seem to be in the 200 on up series currently---but I would suspect that they will "trickle down" to the size of motors we are usually using.
If available, these features might even sway me to get twin 50's instead of the single!
