Rwinemaker
I'm getting ready to install a Profish 700 and I've been imagining every motion I'll likely be going thru when I actually do it. It's going to be hard for me to drill the 1st hole. I have two questions some one out there knows the answer to. The manufacturer points out the minimum clearance required to prevent line tangles. I have a CD-22 and I have a feeling the drop into the locker will be marginal when the locker begins to fill. Are there others using this model windlass on a 22 Cruiser? The next question comes to mind thinking about paying out the line ,where should the end of the line be? Is there a recommended way to terminate so you don't throw your anchor away? I'm learning a lot logging on everyday. Thanks!
