Cutty Sark
Ok Got the battery switch with VSR for Christmas and I am ready to install. I am dizzy from reading Nigel Calders book and would appreciate some help. First off let me say at this point Im not adding any other electrical components or loads, I am just adding a second battery to handle house loads and my loads are fairly small: vhf, downriggers, gps wallas etc...First question is Cable sizing, is 4 AWG large enough to use from battery to battery switch or do I need to go all the way to 2 Awg. Second question: right now the positive to the DC panel in the cabin comes through a thermal circuit breaker and into the cabin. There are a couple items wired directly to the battery terminals( downriggers/wallas/ 2 bilge pumps). Now I want to add a positive buss along with the negative that I am already doing to clean up the terminals a bit. So should I (a) run the positve through the thermal breaker then to the positive buss and branch all electonics from there, (b) run the positive to the postive buss then to the thermal circuit breaker or (c) run two seperate positives, one to the thermal cicuit breaker one to the positive buss? Does this make sense? I guess my question really is that some items want to be wired direct to the battery, namely the downriggers , bilge pumps and the wallas. So should I make an always hot buss since these have their own fuses or should they be behind the thermal circuit breaker for the house too? And if it's always hot should I run the buss straight from the battery or is it ok to have it just upcircuit from the thermal circuit breaker. And lastly in the diagram from blue sea it has an optional fuse from the house battery to the swtch, does anyone use this setup?
See diagram here
http://www.c-brats.com/modules.php?set_ ... _photo.php
See diagram here
