Bill.Secure
Yesterday after running for about two hours my GPS turned itself off and my radio "blinked off and back on". This happened twice about fifteen minutes apart. I was almost home so I just turned them off. Both are the only items on the same 10 amp accessory switch. I figured I'd take the connections apart , clean them, apply dielectric silicon grease and put them back together
As I was getting ready to use the grease, I realized I wasn't exactly sure how to use it (and there were no directions with it addressing usage). I assumed I'd place it on the metal tabs coming out of the circuit breakers and switches and then replace the female portion of the connector. Because the grease is an insulator, I got to thinking that if it wasn't to be used this way, I'd have a heck of a time later on getting it out of the female portion of the connector if I was wrong. Did I have it right and just suffer from cold feet, or is there a more appropriate way to use the stuff?
Bill
Edgewater, MD
Bill
Edgewater, MD
