cuties boat ever.
Captains Cat":2c5ar0of said:
That is cute. What do you suppose the drive mechanism is? A pump on the bottom, an "outdrive"??
Charlie-
I had the same question!
You can see the cable steering to a rudder post, the vertical motor, throttle linkage, muffler, gas tank and fuel line, air cleaner, etc, but no drive mechanism.
Can't see any provision for a V or L drive shaft direction changing device.
Doubt it has a real prop anyway, for safety's sake for this kind of a boat.
I'll bet there an impeller mounted on the outside of the hull spinning on the vertical shaft, with a "clamshell" over the top of it, and with an intake and exit port for the water on the clamshell.
The clamshell design would be interesting to do! (Look at jet outboards for some ideas!)
The rudder sits downstream of the impeller exit port, of course.
The inner and out shaft housing/motor mount and clamshell would probably have been done in sand cast aluminum alloy for cost and ease of manufacture considerations.
Maybe somebody up thee could call this fellow and give us a report? :lol:
Joe. :teeth :thup
How about a "Pocket Pilothouse" instead?
Plan C":2q77g8nd said:
Those boats all look like they have C Dory dinghy potential. We just need to learn how to become smaller people.
Don't worry. If we talk about politics enough here, it will happen. :lol:
