Custom transom boot
stevej
Could not bring myself to install one of the fall apart 5 dollar boots while everything was apart on Shearwater.
Also could not find any quality boots as far as I can tell they don't exist so made some up.
Kenworth shift boot (very heavy duty)
Pro-Comp shock boot
Plastic tube from wire spool
Cut off the bottom two ribs of boot and cut out top
Inserted the top rib into the boot, inserted tube and tie wrapped
Siliconed between ribs and squeezed into cutout, perfect fit and clean appearance. The silicone holds it in place without screws.
stevej
That boot looks perfect. What about a couple over the transom & into the splashwell Salt Water waves & that Batt. S/W? :mrgreen: :beer
Tsturm, the old OMC battery switch survived 13 years without problem so never really thought much about mounting the new one in the same spot. It does get a saltwater wash periodically and they are advertised as waterproof right :wink
stevej
