Tim & Dave Kinghorn
Nigel Calder in the "Boatowner's Mechanical and Electrical Manual" (2005, p. 520) cautions that aluminum tanks are prone to failure (leaks) due to corrosion. He quotes a Coast Guard Boating Safety Circular (#79, Apr. 97):
"Aluminum tanks failed in many different types of boats...were reported to have experienced problems associated with aluminum fuel tanks installed as manufacturer's standard equipment." He details how the major problem with corrosion occurs, particularly where the tank is in contact with bilge water.
On our 23' Venture, the aluminum tanks are a quality product. Each tank has feet with a foot that is about 2 x 4x 1/4" on each corner. We elevated each tank on four 1/2x1&1/2x24" Starboard slats, and we shimmed under each hold down with a 1/4x2x4" piece of Starboard and under each "foot" with a 1/4x2x4" piece of Starboard. In doing so, we became aware of a potential major problem with corrosion due to how the tank was installed by the builder.
On our venture, there is a gutter that goes along each side of the aft cockpit floor and drains across the stern into the sump at the drain plug. The gutter across the stern is fairly wide; and when the tanks are pushed to the stern, the rear "feet" can slip over this edge. Thus, the rear, bottom edge of the tank can rest on the back edge of cockpit floor. Water and debris can then lodge against the tank's back edge. Even when water is drained, there can be a debris laden, wet compress against the bottom of the tank. As the tanks are bonded, you will have a potential corrosion circuit with the other bonded metals. He points out that the critical bilge water level is when bilge water makes contact with metal fuel tanks.
You can easily check the clearance under the tanks with a flash light. But be aware that the bottoms of the tanks are only supported at each corner. Therefore, a full tank may sag a bit in the middle (a bit like my stomach, I fear). Again, debris can accumulate and hold moisture as fuel tanks do "sweat".
It was removing the hold-down lag bolts, that led to our finding water under the aft cockpit deck.
Hopefully we're being overly concerned, but we thought we'd pass along our findings for the general good.
Tim & Dave Kinghorn
Tim & Dave Kinghorn
