Cool new product-nano technology
Hypothetical questions?
Ok, I agree, why wouldn't this be great on the hull, below the waterline, speed should increase?
Ok, would application below the waterline stop the need for bottom paint, too slick for the algae, barnacles etc. to attach to?
Ok then, treat the prop, would it cut down friction, then the reduction in friction would reduce cavitation, I.E. increased engine performance and reduce fuel consumption?
Ok, treat trim tabs, transducers, cut down drag?
What else?
Regards,
Ron Fisher
I have this vision of the boat skittering across the water uncontrolled just short of 60knots after coating with this stuff. Or just flipping bow over transom with a bit of throttle. Could get dicey...
Setting aside the Three Stooges scenarios, without the normal friction between hull and water I can't imagine how a hull might really react. But, I'd think that fuel economy could be much improved. What say the scientists?
Considering gas at $4/5 dollars per gallon, extrapolated forward, “if the stuff" worked and did positively affect economy/drag, $100 per ounce could be a bargain.
Regards,
Ron Fisher
New meaning for the fly fisherman's dry flies
A replacement for rainex on glass
You could wear underwear till it fell off
never hydro plane again, spray your car tires
Put it in with hair spray women would not have to get crazy about umbrellas because of rain ruining their boufant (hairdos)
spray on you balsa cored boat to prevent core rot
Spray it on your cell phone
Spray your anchor rode no more smelly anchor compartment
This isn't new technology, Clark Griswold first developed this in 1989 and demonstrated it on his snow saucer. WOW! Just don't get this on your prop, you could run 2000 RPM without moving two feet!
