Sneaks
- Joined
- Jun 6, 2004
- Messages
- 2,020
- Reaction score
- 0
- C Dory Year
- 1993
- C Dory Model
- user_field_choice.c_dory_model_16_Angler
- Hull Identification Number
- CDO22241H405
- Vessel Name
- C-Brat
Since my backup solenoid valve failed on the Pacific trailer, I'm considering a switch to DOT 5 while it's down for repair.
The DOT 5 label procedure involves draining the DOT 3, "flushing" and then filling and bleeding with DOT 5. Flushing with what? Some say alcohol, some say DOT5 (at $30/qt.)
There are a few tech articles like this one around but none really pertain to boat trailers which, IMHO, are perfect candidates for DOT5.
Bottom line: Has anyone here done the DOT3/DOT5 conversion? Any tips? I'm encouraged by the fact that any possible mixing isn't the "end of the world", so I'll probably do as NAPA recommended: Drain the DOT3, pour in and flush with a few bottles of alcohol normally sold to remove water from fuel, blow out the lines and start filling/bleeding with DOT 5.
Don
Don
