Commuter CD 22 - More modifications
Richard,
Thanks for posting the additional table pictures. The photo of the bottom side of the table gives me a good idea of how you mounted the table to be able to turn it in all directions. It looks like the steel plate may not be centered on the bottom of the table? If it is not too much trouble could you provide the size of the steel plate and dimensions from it to the four sides of the table?
While you are measuring, could you give me the dimensions of the white board the Garelick bracket is screwed into.
I am also curious how the smaller locking knob works? Is there a nut recessed into the table with a big washer between the steel plate and table? Is the locking knob centered on the steel plate?
Once again thanks for the pictures and taking the time to explain how you mounted this table.
Bill Roche
