C-Nile
- Joined
- May 9, 2008
- Messages
- 638
- Reaction score
- 0
- C Dory Year
- 2012
- Vessel Name
- Betty Ann
starcrafttom":mbsuuxmq said:I mentioned this before but will throw it out there again. I would not post it but I helped and saw it happen.
A old guy I knew in California bought a old gold metal flake tri hull ski boat. It was faded so bad I was afraid to touch it thinking I would push thru the fiber glass. He claimed that he could bring it back to life with out a buffer. I said ok and said I would stop by in a few days with my buffer to help out when what ever he had planned failed.
Two days later I stop by and was amazed. He had brought half the boat back to life. It was so shiny and clean it was had to look at. You could see not only your self in the paint but the cars across the street. I was impressed. I asked for his secret. I was told that if i did not believe him and he proved it I had to do half of what was left ( which was why i stopped by anyhow). I bit and he told me, I called bull shit. He then wiped down and 1 by 1 ft area for about 3 min with his secret tool and a rag. No buffer was used. After a good wash the still to be waxed hull was a perfect match to the rest of the shiny boat. I was again impressed and ended up going more then my half of the boat with transmission fluid...... that's right red tranny fluid and a rag will remove the worse oxidation you have ever seen. Just do a little at a time and wash really well right after with a dewaxer or dish soap. ( by the way don't wash your boat or car with dish soap, you are removing the wax) . Then you can hand wax the boat or use a buffer your choice. that boat looked great for the 4 years he lived and was still looking great when his wife sold it.
Tom,
I did some research on the web, and while some people say they found success with ATF, I would highly advise against its use. It may work, because ATF contains a list of chemicals to include anti-oxidation compounds and surfactants. The thing I would worry about is toxicity and running afoul of government environmental regulations. Further, ATF's contain a complex formulation of ingredients that differ by manufacturer over time. You could actually harm the gelcoat. So I would recommend to our readership conventionally accepted methods for gelcoat restoration and protection.
Rich
