I have two boats at work that are rigged with CO detectors straight to the battery. These draw enough amperage to be a hassle in this configuration. I see no reason why they need to be wired this way when we seldom use the heaters, and the heaters on these boats require the electronics system to be turned on. So, why can't I have the CO detector wired to my switched bus instead of my battery? It seems to be a standard configuration to wire straight to the battery, but it only works with the boat that lives plugged into shore power.
Somebody please give me your blessing to wire this to the electronics bus?
