It worked.
The last month, I've had a 1500w inverter installed, juiced with two golf carts and one ordinary deep cycle battery, for the purpose of running a laptop, microwave, and 400/800w quartz infared heater. Took it on a nice run today and it worked beautifully. Cabin was 49 degrees when I started. 10 miles later, a balmy 60 degrees, using the 800 watt setting. All batteries were being charged by the alternator...roughly 12.6v according to the Walmart gizmo. After arriving at my desired temp., I put it on the 400 watt setting to maintain the temperature.
This is a nice alternative to red dot heat, which only works when the engine is on. Also, it's a dry heat in contrast to the propane heat we used prior.
This is not a good option if anchored or docked without shorepower. In those circumstances, we'll use the propane heater (with cracked windows) while awake or the 12v electric blanket while sleeping. In the morning, we can warm the cabin quickly by starting the engine, running the quartz heater, or run the propane heater, or both.
For the first time, we can use our 22 footer in all NW weather conditions and be comfortable. No more Honda genny to haul around and cover when raining.
-Greg
-Greg
