clayhubler
- Joined
- Aug 3, 2019
- Messages
- 406
- Reaction score
- 7
- C Dory Year
- 1986
- C Dory Model
- 26 Pro Angler
- Vessel Name
- Merlin
This happened last summer, before I took Hammerhead apart for repairs. The boat had permatrims on each engine. After pulling her out of the water at Bellingham, my wife says "is that crack supposed to be there?" I do recall hitting a small log on the return run from the islands. It wasn't big enough that I even thought about checking for damage. I do not know for sure what caused this. Both of the lower units were replaced by the previous owner and were less that a year old when this happened. I installed the permatrims after reading about them on this site. I had previously installed the doel-fin hydrofoil, as I had good results with them on the last boat. Perhaps having extra holes from the doelfin caused this?
Anyways, I made an attempt to repair it at the time. I can weld aluminum but not really well. The repair held for a while, but was starting to crack when I removed the motors for the repairs. I think in this case the weld was contaminated because I didn't clean the back (underside) and also I was worried about melting seals in the lower unit, so I didn't weld very much at a time.
I'm going to try and repair this using epoxy and fiberglass. I know there is an etching compound that west system makes for adhesion to aluminum. But I read about some articles by west system and they now recommend g/flex 650 for aluminum. I happen to have some that I bought for another project that I haven't used yet, so I am going to give this a try. Supposedly you can wet out glass cloth with the gflex just like 105. I'm going to grind and clean the area, top and bottom, and then put build up the area with glass. Hopefully I can sand this down and paint to match the rest of the motor. I do not plan to put the permatrims back on, because I am concerned about another failure.
If anybody has any thoughts on this I would love to hear about it.
Thanks all
Thanks all
