oldgrowth
Active member
- Joined
- Jun 27, 2005
- Messages
- 2,199
- Reaction score
- 0
- C Dory Year
- 2002
- C Dory Model
- 16 Cruiser
- Hull Identification Number
- CD015406H102
- Vessel Name
- C-Voyager
Wandering Sagebrush":3jnmpthm said:What's building (boatwise) in the background? Looks interesting.
starcrafttom":3um7gntr said:I would tell you but I cant so I won't. I may or may not have been swore to silence but I cant remember. :wink:
I built it from scratch from 1/8th inch aluminum plate. Same stuff I built the tanks and shelfs with.Dora~Jean":1gu6s6kg said:Also like the generator tray, did you build it from scratch or mod something pre-built?
Larry – my brother and I did them ourselves. He is the welder. I would have to do some checking on aluminum prices. The aluminum plate I used was some we had setting around for many years. Don't know the current price for 1/8th inch aluminum plate.Larry H":2mgu00vq said:Dave,
Never mind the boat in the background, I am curious about those tanks.
Did you design and weld them yourself? If so, would you build them for someone else?
Could you design and build saddle tanks for a CD 22? Any idea on cost for that kind of project?
oldgrowth":ritb7buk said:Larry – my brother and I did them ourselves. He is the welder. I would have to do some checking on aluminum prices. The aluminum plate I used was some we had setting around for many years. Don't know the current price for 1/8th inch aluminum plate.Larry H":ritb7buk said:Dave,
I can tell you, they will be more expensive than most people will want to pay. Your question “Could you design and build saddle tanks for a CD 22?” The answer is we can do just about anything. I would need to see the boat and know what size tanks you wanted.
________
Dave![]()
Bill - Each tank will hold 22 gallons but I rarely put more than 20 gallons in each tank. I can use fuel out of either tank individually or both at the same time. With my switch on both, the tanks will self-level until I have less than three gallons per tank.Best Day":3k75a1cd said:Very nice looking construction and install on the tanks. They look very professional and add fuel capacity without losing usable space.
How much do they hold?
Bill
