C-Dory 19 Trailer
Do you want a single or double axle?
Do you prefer bunks or rollers?
What type of braking do you want? (hydraulic, electric, surge)
Answer those if you can and I am sure we can make educated guesses at least.
In the meantime, I will tell you what we use as one example for a heavy 19.
King
KB3700S
APPROX. BOAT LENGTH RANGE: 18'-20'
LOAD CAPACITY: 3700
APPROX. OVER ALL LENGTH: 22' 11"
APPROX. OVER ALL WIDTH: 102"
WIDTH BETWEEN FENDERS: 80"
BOW EYE TO TRANSOM MIN.: 15' 10"
BOW EYE TO TRANSOM MAX.: 20'
APPROX. WEIGHT: 840 #
TIRE SIZE: ST225/75 15D
TONGUE JACK: 1000 #
NUMBER OF BUNKS: 4-10'
COUPLER SIZE: 2"-CL3
Greg
My EZ Loader trailer didn't seem to match the specs on the EZ Loader site, so I called them and gave them the serial number. They are computerized enough that they knew that my 2004 trailer originally sold in Canada and even knew the dealer and trailer specifications. My particular model was no longer in production and the specifications were slightly different than present models and were even slightly different than those given on the trailer's spec sticker. They knew that it had sold with an axle upgrade that wasn't listed on the sticker.
All of this is just to say that whatever somebody else's EZ Loader is or says on the sticker doesn't always help when looking for a new trailer. Plus, mine was further modified by the PO (folding tongue) and has now been even further modified by me.
A call to EZ Loader might be the way to go. Both times that I called they were extremely helpful. They might have the CD 19 specs on file and may even know if a dealer in your area has one in stock.
Mark
