Kent Richmond":3dv3bfan said:
Thanks for the info. The smaller space is not a problem for us as we do our camping in the "land" camper. I have decided to look at the 19 angler also, but sure like the towability/storability of the 16.
Kent
Sounds like you're the perfect match for a 16. Angler, of course...(sorry Cruiser owners
There's a world of difference between a 16 and 19 - I've owned both. If you are looking at 19's, go ahead and look at 22's while you're at it. In particular, look at the 22 Angler...has roughly the same size cabin as the 19 (although it's enclosed), and you'll love the massive cockpit.
There's far more similarity between a 19/22 than a 16/19. A 19 is simply a 22 with the middle cut out, and no aft bulkhead on the cabin. Powered the same, same tow vehicle, roughly the same fuel usage, etc.
A 16 has a far narrower beam, uses almost half the power, at least 1/3 less fuel, and is far and away the easiest C-Dory to handle - on or off the water, at least in the protected conditions you describe.
And finally...it is by far, the coolest C-Dory. Fonzie would have owned a 16, no doubt about it. It's also a little known fact, that chicks dig 16 Anglers, even more than puppies. Wish I knew this back when I was single...
