C 22 towing behind slide in camper
al and judy
Mar 15, 2007
31
Judy Lynn
We are eagerly anticipating our first C22 cruiser, the JUDY LYNN. A concern has arisen about towing with our slide in camper on the truck. The truck is a Ford F350 super duty TD with an 8 foot bed and a factory receiver. We carry a 9.5 S-S camper which extends over the factory receiver by at least 1.5 foot. The C22's we have looked at have very little "free" space in the tongue. We were hoping that someone out there has advice on how to best deal with this issue.
This is our first post and we look forward to many years of enjoyment with our new friends the C-Brats. Come to think of it---we're C-Brats now so I guess we're family! :D :D
Al,
I have an extension I bought at Mobile Trailer Supply that I think is rated to 5000 lbs. It offers about 16 inches extra length so might work for you. I would ask the people at Mobile Trailer about weight ratings. You can try mine if you are interested. It was for a setup I no longer have. Another of my collection of parts.
Tom
Al and Judy
We presently tow our 22' with a Chevy 1 ton duramax duely. Can't hardly tell its back there. In the future planning on a 10.5 ft camper. Figure we will need either a 18" or 24" extension. You shouldn't have any problems with up to a 18" extension. I have used a 18" extension on my previous pickup with factory hitch. It was a 3/4 ton chevy crew cab. I was well within hitch rating. You also need to check the combination camper and boat tongue weight to see if its with in your pick up weight rating.
With a 18" extenion your identical with camper on to no extension and just your truck, so if you have enough free space without camper should be fine with a 18" or maybe even the 16" that Tom has.
The below web site rv.net truck campers provides much useful information in this area.
http://www.rv.net/forums/index.cfm/fuseaction/lis
We used a GMC crewcab dually with a 11.5 Lance to tow our 8000# boat for thousands of miles. The Lance had plenty of overhang in the back.
We basically used the following system: http://www.reese-hitches.com/extensions_adapters.htm.
We stablilized the unit so it would not shift horizontally and used a weight distribution hitch setup. Absolutely no problems with it.
Good Luck.
I have an f-350 and a Lance 1130 camper (12ft). I had to upgrade to a class 5 hitch 2 1/2" and have a 4' extension with safety chains. It has a tongue rating of 750 lbs and 14,000 lb tow capacity. Have towed the Hammerhead from Sacramento to Bodega Bay and Lake Tahoe Many times without any problems.
Doug
Al- An extension as Tom stated would work or call your trailer manufacture and buy a longer tongue arm. Most if not all are bolted and with a little labor can be made longer. My Father was in the same predicament and did this. This may be the most cost effective way to deal with it.
Chris Bulovsky
Al & Judy,
You picked a great name for your new boat ! Welcome aboard !
Paul & Joni aboard the JONI LYNN
Thanks to all. You have supplied more than enough info and links to help me make an educated decision. :D
