blue stripe abrasions
dotnmarty
Got a few abrasions on the blue stripe. No depth to them, but white does show through. I tried to compound them out but it didn't work. Any suggestion? Thanks
You're lucky, Marty. I saw the headline and I thought for sure this was another political rant.
I suspect that C Dory still uses the same gel coat color as they have for some time--and you could get a small amount from the factory. (I got a quart of green and of white with my boat when it was new).
Spectrum color can match any boat's gel coat--and you can get the small kit for $21.50 plus S&H: http://www.spectrumcolor.com/catalog.htm They give C Dory from 2000 thru 2008 available. Since you have a boat in that time frame, they should be able to accomidate you. I have used their products on several boats--including the Century which had a lot of damage, and even 3 years later you cannot see the repairs.
