tpbrady
- Joined
- Feb 7, 2005
- Messages
- 891
- Reaction score
- 0
- C Dory Year
- 2005
- C Dory Model
- 25 Cruiser
- Vessel Name
- Bidarka II
On my CD-25, the cabin bilge pump is set up with separate DC connections for the the float switch and the helm switch. The original Rule 1100 Automatic pump was designed this way. Last summer the float switch in this pump failed in the on position and since then has completely failed. The manual switch still works. I have a spare float switch and plan to disconnect the DC to the original Rule float switch and seal up the end of the wire. I will then splice the DC from the battery (it is fused at the battery) to the float switch and then connect the float switch DC out to the same DC input on the bilge pump as the switch from the helm. Basically, this means the bilge pump can be powered by the float switch "floating" for manually from the helm. Are there any flaws in this approach that I am missing?"
