mikeporterinmd":1nd1bcdp said:
Anyone know what the largest size pump is that will fit into the little
galley pump area on a CD-22?
My "automatic" pump failed, so I think I'm just
going to switch to a Rule 1500 or 2000 and Superswitch, if it fits.
Mike
Mike-
Do you also have another bilge pump at the rear in the well just forward of the center of the transom? If so, that pump will be the primary pump when the boat is running with the bow up.
I don't have the forward well under the galley like you, but I'm wondering if a really big pump will work there.
It's my understanding that this forward well was added to eliminate water at rest when the boat is not moving, or at displacement speeds. Standing rainwater has long been a problem in the C-Dory design which has a lot of rocker (fore and aft curvature) in the flatish (side to side) shaped semi-dory hull. Some boats will accumulate 3 inches of water before the rear pump goes to work, and it still will not eliminate much of the forward water against the doorway!
Heavier 4-stroke engines have partially made this problem less severe, but the factory added the mid-ship / under galley pump specifically to cure that problem.
Specifically, what I'm wondering is that if the larger size pump and float are not only unnecessary in the forward well, but more importantly, if their larger dimensions will work well in that situation.
It's not just whether the body of the pump and switch will fit, but also if a taller intake grille/screen on the pump and the larger float switch will require more (higher) water to switch on to begin with, and whether they will be able to take the water down to as low a level as the smaller pump that was originally supplied (OEM).
Of course, only a physical examination of the two different pumps and switch will be able to determine this, but I thought I might bring it to your attention.
Joe. :teeth
