Battery terminals
pcator
Aug 7, 2006
151
2007
25 Cruiser
Donna Marie
Can someone recommend a product that will cover terminal posts + screws + a whole bunch of wires coming off the screw head?
Tks
Patrick
I ended up crafting one for each battery from a small square or rectangular tupperware type container. Cut out slots for the cables to pas through. Most batteries have both a screw on terminal and a slip on. The slip on has a red or black thimble looking cover. I hot glued the thimble to one of the inside corners of the tupperware box and then slipped that back over the terminal which holds it on.
I had a idea last year to use tennis balls with a large circle cut out. I would then kind of force these over the posts an wires. I bought the balls but that's all the farther I got. I'm going to go down to the boat right now and re-start this project! Seems like it should work, I'll let you know.
Patrick, why not put the whole shebang in a plastic battery box with a cover on it? There is usually a big "notch" in the cover to lead out wires.
Patrick, I use the plastic battery boxes, and CRC terminal spray from Advanced Auto.
BTW...your rope extender thingamabob is repaired and ready for pick-up... :lol:
