dogon dory
- Joined
- Jun 10, 2004
- Messages
- 1,321
- Reaction score
- 0
- C Dory Year
- 2005
- C Dory Model
- 22 Cruiser
- Vessel Name
- DogOnDory
Falco":344mihrz said:(Apr 15, 2006) OK, Robbi:
blah blah blahblah, blah blah. (LOL)
It turns out this Blue Seas battery selector switch has AFD (forget about what it means - you need it) built in:
http://www.bluesea.com/product.asp?Product_Id=31165
I just put one on my boat and plan to swap out my other no-doubt-soon-to-fail Guest switch with another. I like it alot. Very compact, solid.
Let us know what you learn from the book...
It was a GREAT idea but so far has had a few problems. The location I selected is definitely the right one to tie everything together. However, since screws or thru-bolts aren't an option there another solution is required. The "super velcro" would work perfectly if the mounting surface were flat. Sadly, it isn't. My last attempt entailed propping wooden dowels to hold the panel in place until the velcro backed adhesive could cure. So far so good. I will require more time before I could reccommend it to you however. Those halibut trips you take can be rough and you don't want your panel flopping around. However, there is a solution that I guarantee will work. Get some( 2 or 3 or 4 ) small wooden or plastic "firring strips" the height of the panel and 5200 them where needed. Then simply screw the panel to them. That is the way I attached a 1/2" plywood circle to secure my old guest swich. It held for 15+ years. As to the system itself I can say it's WONDERFUL. The starting battery is always brimming, the electronics are totally isolated, and I have no switches to manage. It's just great !How has your mounting board with the velcro held up?
