Les Lampman
Electricity is a funny thing for folks: some understand it, some sort of understand it, a lot don't understand it at all. For folks that have a good working knowledge of electricity and their systems there are lots of ways to make things work. The same way an experienced driver can make a 15-speed Road Ranger transmission work in a semi...most of us have automatics in our cars and trucks (or maybe a 5-speed). That there is the gist of the difference between setting up a good system or setting up a tolerable system. It's all in the understanding.
Realizing that most folks drive automatics (statistically anyway) I tend to install systems that don't require much understanding from the owner/operator (do you really want to know how that automatic works?). Most folks derive pleasure from using the boat (a few sick individuals actually derive pleasure from working on them) so another goal is to keep the system working 100% of the time without user intervention.
Technology has given us the means to do so simply and without extraordinary expense. In fact a look at the West Marine Advisor will show that their recommended system is simple, robust, and easy to use.
You can flip switches, keep track of the last time you chose a different battery, look at the voltage to check to see if you need to charge a battery, etc or you can install a system that requires you to place the battery switch in the "on" position and then go boat...your choice.
