cemiii
- Joined
- Feb 25, 2008
- Messages
- 419
- Reaction score
- 0
- C Dory Year
- 1987
- C Dory Model
- 22 Angler
- Vessel Name
- The Last One........ III
I have a back up bilge pump. I envisioned its main function to be in case of the primary pump malfunctioning. However, it certainly would assist in the event of needing greater capacity in a major incident.
When I installed the back up, rather than cutting a second thru-hull, I simply ran the new disharge through the motorwell boot. I've been trying to think this through as to whether or not it is worth rerouting to a higher position. Even in the unlikely situation that the boat took on enough water that that discharge hose was nominally below water, would the little bit of backpressure seriously impair the function?
Chris
Chris
