This is Mysterious Black Spots revisited. My boat is covered with these tiny hard shelled black spots that contain a tarry substance that stains the fiberglass. These spots are called Artillery Fungus, visit http://plantclinic.cornell.edu/FactShee ... fungus.htm
These spots are caused by decaying wood chips. I have a wooded lot where the trees were cleared, logs hauled off and branches chipped into a large pile in amongst the trees. These are pine and oak chips. After moving into my new home I stored the boat next to these trees. These spots, per this article, are virtually impossible to remove. I can say that this is true. I've tried everything I can think of with no luck. I can scrape the hard shells off but the stain remains. My next resort is 600 grit wet/dry sandpaper. One suggestion was to try MEK. I read the label and it sound potent. Does anyone have experience with MEK? Is it safe to use on my fiberglass? My gelcoat is old and weathered so that doesn't help. This is becoming a large problem in the Northeast, so I've read. Keep your boat away from piles of wood chips.
I'm open for suggestions.
Dick
Dick
