terraplane
This is tom/terraplane...been wanting to check out some things for some time, and now that there are some battery gurus on line here....
22 cd, new in 2005. Sally's Sister..been great no problems. Standard factory setup. mostly, but.Guest 10amp Charge Pro, two Optima blue top batteries, Perko switch (1,2,all, off) Shore power...
l. Should shore power be used just spoadically,; does it harm batteries to leave it hooked up for longer periods..couple of weeks?
2.When starting, do i start always with just one battery, and use the other just for house use? Or do I start with both on.
3.Do I shut off batteries when i'm at the dock for several days.
4. My batteries on on the deck, secured, between the gas tanks, sitting in trays and strapped down, just in front of the second bilge pump in stern. Water tends to collect in the black plastic trays..is this harming the batteries.
Guess that's it...any comments welcomed.
tom
tom
