Jack in Alaska
- Joined
- Aug 17, 2004
- Messages
- 1,192
- Reaction score
- 0
- C Dory Year
- 2005
- C Dory Model
- 26 Pro Angler
- Hull Identification Number
- CD026021I405
- Vessel Name
- HIGH TIDE II
I have always used 3 strand 3/8" anchor line until last year. I decided to treat myself to a new double braid line and I purchased a 600' spool of 3/8" at a hardware store here. After putting a thimble on each end and marking off distances in 100' intervals I installed it on my boat with 20' of 3/8" chain and a Bruce anchor.
I always pull my anchor with the split ring and a buoy. The 3 strand line pulled without problems every time. The new dbl. braid has consistently tangled up enough to stop the split ring/buoy from completely pulling the anchor/chain to the surface. When letting up on the power the anchor heads back to bottom. Sometimes it takes 3 attempts to retrieve it.
What is wrong???? Can it be a cheap dbl.braid that lets the outer casing bunch up stopping the split ring.???
No amount of power will make it come up.
I think the dbl.braid is going into the trash and a new 3 strand is in my future.
Any ideas would be appreciated.
Pulling the anchor that way is dangerous enough if all works right but when having to stop and redo it several times is not fun particularly in a rough sea.
