Just when you think you have all the core penetrations under control, another one pops up.
Last week I was replacing the horn, which had failed after a long road trip in winter slush/salt conditions. The existing horn wiring and mounting required that I remove the all-around anchor light mounted on the flat spot behind the brow.
Guess what?
Yes, another half-inch donut of punky balsa due to a sloppy sealing job.
While examining the fixture, I noted that even if the perimeter caulking was good, that the light would have let water through the bottom of the socket into the exposed core.
The lesson here is that you should check your bedding, remove the light, and install the cap when you don't need the light.
Guess what?
