Doryman":3rk8xmi6 said:
Matt -- A question about gearing for Honda, Yamaha and Suzuki. I have noticed that Suzuki gearing is more aggressive than that of Yamaha and Suzuki. For the 150s:
Honda -- 2.14:1
Yamaha -- 2.00:1
Suzuki -- 2.50:1
Several people here prefer Suzuki for performance. I am wondering why the other manufacturers don't match those gear ratios -- I don't believe the lower gear ratios on the Hondas and Yamahas result in significantly more economy, if reports from the field are to be believed. So what are the tradeoffs here?
Warren-
The Suzuki is actually
lower geared than the Honda and Yamaha, which turn the motor 2.14 times and 2 times, respectively, for each revolution of the prop, because the Suzuki must turn it's motor 2.5 times to get it's prop to turn once.
(I guess ratios have to be understood from which side of the numbers your on!)
As I understand it, the advantages of the lower gear ratio on the Suzuki is that the resulting
slower turning prop with a higher pitch is
1. less likely to cavitate than a lesser pitched (and probably smaller diameter) prop that is turning faster, and
2. should have less frictional loss, since the speed of the water accros the slower turning blades should be slightly less.
There are probably more advantages and/or trade-offs, too, but these are the two I can think of right now.
I made an analogy once using a row boat. You could row the boat with three foot oars or 8 foot oars.
Either would propel the boat, but the three foot oars would waste a lot of energy splashing around a lot, whereas the longer 8 footers would transfer the
energy more efficiently.
Of course, the analogy is exaggerated to more than the gear ratio differences, but the idea is the same.
Hope this makes sense (and
holds water too!)
Joe. :teeth :thup
