I AM IN THE PROCESS OF PURCHASING A 1981 C-DORY ANGLER, HULL #8 WHICH IS LOCATED AT EQ-MARINE IN OAK HARBOR WASHINGTON. I DON'T THINK THIS BOAT HAS A NAME, ALTHOUGH IT DOES HAVE HUNKY DORY WRITTEN ON THE SIDE. THE QUESTIONS I HAVE FOR ALL THE C-DORY ENTHUSIASTS ARE:
1. AFTER A HULL SURVEY MULTIPLE PROBLEMS WERE DISCOVERED, DELAMINATION IN HULL BOTTOM, AREA OF "HIGH MOISTURE CONTENT" AS WELL AS AN AREA THAT HAD A BREACHED OUTER FIBERGLASS LAMINATE SECONDARY TO HIGH POINT LOADING, POSSIBLY CAUSED FROM BOAT SITTING ON A ROCK WHILE BEACHED. GIVEN THAT THE TRANSOM HAD ALREADY SUFFERED FROM A ROTTEN CORE SECONDARY TO WATER INTRUSION, (WAS REPAIRED) WOULD THIS BOAT BE WORTH 15K, GIVEN THE COSTS ASSOCIATED WITH FIBERGLASS REPAIR.
2. THE OTHER QUESTION INVOLVES THE SURVEY. I LIVE 10 HOURS AWAY FROM OAK HARBOR SO I RELIED UPON THE SALESMAN AT EQ-MARINE FOR A MARINE SURVEYOR REFERRAL. THE SURVEYOR GAVE ME A PHONE REPORT ON THE EXTENT OF DAMAGE/PROBLEMS WITH THE HULL BOTTOM AS WELL AS DISCUSSION ABOUT OBTAINING CORES TO EVALUATE THE FULL EXTENT OF MOISTURE MIGRATION AS WELL AS DELAMINATION OF HULL CORE. AFTER THIS DISCUSSION I ASKED THE SURVEYOR ABOUT BEING COMPENSATED FOR HIS TIME AND HE SAID, "THERE IS NO CHARGE." I ASKED WHY AND HE STATED, "THERE WAS NO SURVEY." I THANKED HIM FOR HIS GENEROSITY WITH HIS TIME AND GAVE IT NO FURTHER THOUGHT HOWEVER, LATER, AFTER REFLECTION ON THAT DISCUSSION, MY CURIOSITY PEAKED. PER MY AGREEMENT WITH THE EQ-MARINE SALESMAN, I WOULD BE BILLED $200.00 DOLLARS FOR THE SURVEY IF IT SHOWED NO HULL PROBLEMS AND THAT HE WOULD PAY THE $200.00 IF IT THE SURVEY WAS BAD.
THE QUESTION FOR THE C-BRATS IS WHY WOULD A SURVEYOR CONDUCT A SURVEY, PUTTING THE BOAT ON BLOCKS, UTILIZING MOISTURE METER AND HAMMER TESTING HULL, PROVIDING PHONE REPORT TO POTENTIAL PURCHASER AND THEN NOT BILL FOR TIME AND DENY A SURVEY WAS EVER DONE?
THE LAST QUESTION INVOLVES CORE SAMPLES. PER THE SALESMAN AT EQ-MARINE, THE OWNER OF THE BOAT IS GOING TO ALLOW "MINI" CORE SAMPLES TO BE TAKEN. WHAT IS A "MINI" CORE SAMPLE? PER MY RESEARCH CORE SAMPLES ARE ALWAYS AS SMALL AS POSSIBLE, YET LARGE ENOUGH TO EVALUATE THE HULL CORE AND LAMINATES.
I HAVE BEEN SAVING FOR THIS BOAT PURCHASE FOR QUITE SOME TIME AND CANNOT AFFORD TO GET IN OVER MY HEAD WITH HULL REPAIRS, HENCE MY REQUEST FOR ADVICE/GUIDANCE FROM PEOPLE THAT HAVE INTIMATE KNOWLEDGE ABOUT C-DORY BOATS.
THANK YOU,
T-DOG
THANK YOU,
T-DOG
