potter water":3fe945mk said:Static testing of the engine in the water is going to create a much different temperature response than if you are moving through the water. You are basically lugging the engine at much lower RPM than you would experience out on the water. That is the reason that shops use test props that don't push water.
You may have fixed the problem and don't know it because of the way you are testing.
Put it on the lake and take it for a spin if you want to compare apples and apples with the times you were on the water and noticed the problem. Static testing is very hard on the engine without a dummy prop and will cause overheating.
Your shop guys should know about that potential problem and potential damage to the engine doing the testing that you are doing. Flushing the engine is one thing, but operating statically at high RPM's is not good.
Think of it as a car that has the wheels locked and you are popping the clutch. Something will give--xmission or engine overheat etc. Same thing with the testing you are doing.
Granted you are correct, the motor is lugging. That doesn't account for the fact the temperature stabilized at 150 degrees for over 5 minutes, than all of a sudden on restart rose above 210; it's obvious a problem still exists.
This has a short duration static test, hardly enough to do damage; also recommended by Murcery Factory technician.
