Will-C
- Joined
- Aug 21, 2007
- Messages
- 2,476
- Reaction score
- 1
- C Dory Year
- 2008
- C Dory Model
- 23 Venture
- Hull Identification Number
- CD023007A808
- Vessel Name
- Will-C
I have always noticed a small amount of water in our bilge area. It started to increase. After our last week long cruise. I checked the three screws on the bronze flange that our threaded drain plug threads into, all three were loose. I had to drop a large zinc off the motor to get to the highest screw. I pulled off the flange which has some sort of flexible black sealant. I scraped it clean and drilled out the holes with a 5/16 drill and under cut the the holes where the screws go with cutter in a dremel tool. I used some West System Six 10 thickened epoxy adhesive. It comes in a tube that fits in a standard caulking gun. The tube features a two part epoxy that gets mixed by threading on a mixing tube on the end of the tube. I filled the three holes and actually coated the complete hole in the boat that goes into the bilge area with the same epoxy as it does not look like it was ever sealed properly as some core looked like it was exposed. After letting the epoxy cure for two days I drilled holes for the screws that hold the flange on to the boat. I installed all three screws and made sure they would come tight. I then removed the flange and coated the inside of the bronze flange with 3M fast cure 4200 and reinstalled the flange. The nice part about the Six 10 epoxy tube is that You throw away the mixing tube after unthreading the mixing tube to save the rest of the tube. New mixing tubes come two to a pack. At 22 dollars a tube the epoxy is a little rich but you don't have worry about it being mixed right. It comes with a plug that you can reinstall that separates the two parts and a nut that holds the plug in tight. I replaced our two lazarette covers and had done the same drill out under cut and refill with epoxy and redrill and used the same tube for that project. I'm not sure if the bronze flange comes loose on all Ventures but you might want to see it those three screws are tight in your bronze drain plug flange.
D.D.
D.D.
