JMacLeod
C-Dory Year: 2018
Vessel Name: C-Shalom
Photos: JMacLeod
Posted: Fri Nov 02, 2018 7:43 am Post subject: Kayak and dingy racks? |
I've seen photos here and there, but haven't found any discussions yet on installing/making roof racks for the C-Dory.
The simplest idea I had so far was to install a couple of 12" grab handles on the edge of the roof to act as a kayak stop and attachment point for retaining straps.
I'd love to know what everyone's best solution has been for kayak and dingy roof holders?
Bonus points for links to photos in your album.  |
RobMcClain
Vessel Name: Freedom
Photos: Freedom
Posted: Fri Nov 02, 2018 9:32 am Post subject: |
I have an inflatable Sea Eagle Fastrack 385ft tandem kayak. It is ~12' long and weighs only 32 pounds. Being so light allowed me to build a rack out of PVC piping bought from Lowe's. Because I have a solar panel on the cabin top located just behind a radar dome, I had to elevate the kayak over both. You can see photos of the rack in my photo album, I believe in the Projects sub-album. The rack works wonderfully. It's easy to put on when we take the kayak with us and the boat doesn't move an inch. I use 2 rachet straps across the kayak to hold it down, plus a line from the bow to the bow cleat on the boat. The cross bar on the rack rolls which makes it easier to load and unload the boat since otherwise the material of the kayak sticks to the PVC and easily won't slide. The cross bar is one piece of tubing inside another and I just put a small screw hole thru one side of both that I can put a screw into to prevent rolling when loaded. By the way, I highly recommend the Fastrack 385ft. It is a wonderful kayak for 1 or 2 people. It's fast and stable, carrys a good load, and tracks quite well.
Rob |
Joined: 01 Mar 2005 Posts: 7488 City/Region: from island boy to desert dweller
Posted: Fri Nov 02, 2018 9:37 am Post subject: |
We bought an inexpensive roof rack (universal fit) at Walmart and connected the cross beams to the hand-rails on the roof...
I use J-hook racks, but found the one for the Hobie kayak wasn't a good fit; so, we used one set of J-hooks and put pool noodles on the cross beams for the Hobie to sit on. This kept the kayks off the roof (no scratches).
With an inflatable dinghy, we just set it on the roof and ran quick rachet straps over the dinghy and connected to the hand-rails.
Anything that takes a lot of set up or fuss won't get used as often.
Hope that helps. |
Marco Flamingo
Vessel Name: Limpet
Photos: Limpet
Posted: Fri Nov 02, 2018 11:11 am Post subject: |
RobMcClain wrote: | I use 2 ratchet straps across the kayak to hold it down, |
I don't have a dinghy, but I do use ratchet straps. They are available in stainless steel (mechanism) if you are in saltwater. The hooks may still be rubber coated steel, which can wear through and rust depending on how rough of use they get. The SS ones will last years, although the nylon straps may have to be replaced. Nothing more frustrating than a corroded ratchet that won't spin while you are balancing on the side of the boat.
Mark |
Montana Kev
Joined: 25 May 2007 Posts: 318 City/Region: Bozeman/Yellowstone
State or Province: MT
Vessel Name: Grace
Photos: Grace
Posted: Fri Nov 02, 2018 11:54 am Post subject: |
This thread has some good roof rack options with photos - http://www.c-brats.com/viewtopic.php?t=23000
We used a simple wood rack for a few years on the 22. The last couple years we have used a Yakima rack that clamps to the roof rails. Both options have been easy to remove for installing the winter cover. |
johnf
Joined: 12 Jan 2005 Posts: 340 City/Region: Tigard, OR
ken35216
Joined: 12 Mar 2013 Posts: 577 City/Region: Destin, Florida
C-Dory Year: 2017
Vessel Name: Lady Onyx
Photos: ken35216
Posted: Sun Nov 04, 2018 2:21 pm Post subject: |
 _________________ 2007 25 Cruiser 150 Suzuki (2013-2016)
2017 25 Cruiser 200 Yamaha (2017-present) |
jkidd
Joined: 23 Oct 2006 Posts: 1677 City/Region: Northern, Utah
Vessel Name: Voyager
Photos: Voyager (JK)
Posted: Sun Nov 04, 2018 6:12 pm Post subject: |
Thule towers and bars wrapped with carpet.
 _________________ Jody Kidd
KE7WNG
Northern, Utah
