Kayak project complete on 23 Venture
johnf
City/Region: Tigard, OR
PostPosted: Mon Apr 30, 2018 10:48 pm    Post subject: Kayak project complete on 23 Venture Reply with quote
Wanted to share my latest project for the 23 Venture...
Found Mantus Marine (love my 13 lb anchor) has stainless steel rail clamps in 3 sizes...7/8, 1 and 1 1/8 (I used the 1 inch).
Then I learned about a shaft collar with a 1/4 20 bolt hole (removed the set screw) which I placed inside of a 1 inch stainless steel pipe and ran the bolt through a drilled hole.
Used Yakima clamp racks on the pipe...pics in album under 2018.
Hope this helps others with their kayak rack project ideas.
John CoolSmile
PostPosted: Tue May 01, 2018 4:48 am    Post subject: Reply with quote
Howdy John. That looks really nice, keeps them low and sturdy. Great job, thnx for sharing.
johnf
PostPosted: Tue May 01, 2018 8:51 am    Post subject: Reply with quote
Thanks Harvey...it took me a while to see the vision using the Mantus clamps but I have to give credit to the local Ace Hardware guy for putting me on to the shaft collar which helped secure the bar to the clamp.
Getting excited to get up there and see the gang!!!!
Wandering Sagebrush
City/Region: Northeast Oregon
Vessel Name: Constant Craving
Photos: Constant Craving
PostPosted: Tue May 01, 2018 10:19 am    Post subject: Re: Kayak project complete on 23 Venture Reply with quote
John CoolSmile
John, that looks very nice! Thanks for sharing!
PostPosted: Tue May 01, 2018 4:18 pm    Post subject: Reply with quote
Clean install. I like it. Cool
These are pretty slick. https://www.youtube.com/watch?time_continue=58&v=YKhvG80YtOw
Yakmandu
City/Region: Lake Lanier
State or Province: GA
C-Dory Model: 19 Angler
Vessel Name: Miss April
Photos: Pops GO!
PostPosted: Tue May 01, 2018 9:36 pm    Post subject: Reply with quote
Nice work! Do you have any part numbers or sources for the cross tubes and shaft collar? I might try something similar to mount my solar panel and leave room for a kayak.
Thanks for sharing your work!
Patrick Rohde
Miss April
Lake Lanier, GA
johnf
PostPosted: Tue May 01, 2018 10:57 pm    Post subject: Reply with quote
For the stainless steel 1 inch pipes I used amazon...each was 5 feet long and I cut it to the length I needed.
For the shaft collars I used Ace Hardware and ended up finding the right size in Orchards...you want a shaft collar that barely slides through the pipe to the other end.
Keep in mind where you drill your hole for the Mantus clamp because you have line up the threads of the shaft collar to the hole to screw in the clamp.
I later purchased (online) 4 saddle washers to futher stablize the area of the bolt through the pipe. The saddle washer is flat on one side and like an inverted saddle on the inside to align with the pipe (had to learn about these as well).
Glad this might help you with your project!!! Enjoy!! Please share pics when done will be anxious to see your end result...
Salmon Fisher
City/Region: Arlington
Vessel Name: Kim Christine
Photos: Kim Christine
PostPosted: Mon May 07, 2018 12:29 am    Post subject: Reply with quote
Excellent work John! Can't wait to see it up close in Friday Harbor!
Patrick and Kim Walker
2004 25 Cruiser-Present
1985 22 Classic -2019 (Sold)
Ordutch1975
City/Region: Portland
Vessel Name: Boatless :-(
Photos: PennyBridge
PostPosted: Mon May 07, 2018 3:30 am    Post subject: Reply with quote
Wow, looks great! (I love my mantis anchor too)
"And it is an interesting biological fact that all of us have, in our veins the exact same percentage of salt in our blood that exists in the ocean, and, therefore, we have salt in our blood, in our sweat, in our tears. We are tied to the ocean. And when we go back to the sea, whether it is to sail or to watch it, we are going back from whence we came. " -JFK
Page generation time: 0.0271s (PHP: 75% - SQL: 25%) - SQL queries: 22 - GZIP disabled - Debug on
