Wallas fuel
bridma
City/Region: Comox
Vessel Name: Nomad
Photos: Nomad
PostPosted: Sun May 06, 2012 10:50 pm    Post subject: Wallas fuel Reply with quote
From what I have read on this site, deasil gives out a higher heat btu than kerosene on the Wallas. I presently use kerosene (no problems), if I switch to deasil, do you think I can just run down the kerosene to low and then top up with deasil, or do I need to flush the system clean before switching to deasil? If I need to flush, what is the procedure?
Martin.
SPrice
City/Region: Camano Island
Vessel Name: Absolutely
Photos: Absolutely
PostPosted: Mon May 07, 2012 1:14 am    Post subject: wallas stove Reply with quote
I talked with the Wallas guys at the boat show. You can switch and not worry about cleaning out before you use diesel or vis- a - versa. I do not know about which give out more BTU's.
SPrice
KevinDU
Vessel Name: Sea Otter
Photos: Sea Otter
PostPosted: Mon May 07, 2012 1:39 am    Post subject: Reply with quote
DIESEL
PostPosted: Mon May 07, 2012 8:35 am    Post subject: Reply with quote
For colder climates, regular diesel gets some kerosene mixed in... you shouldn't have any issue putting diesel in there with the kerosene.
We are still using Kleen Heat with our Wallas. Picked up two more containers before we left home. You can store it, easy to carry, and it doesn't smell (much).
http://captnjim.blogspot.com/
macmac
PostPosted: Wed Jun 06, 2012 11:22 am    Post subject: Fuel Reply with quote
Please be careful about posting fuel comments! This string of posts says nothing about what kind of Wallas device you are discussing.
Wallas builds two kinds of devices - those that burn diesel and those that burn kerosene. Burning kerosene in a diesel product will usually do no harm to the device. Burning diesel in a kerosene device WILL damage it very quickly.
Best advice: Burn diesel in diesel devices and burn kerosene in kerosene devices.
One last point: Diesel #1 and kerosene are NOT the same thing!
Thanks for using Wallas!
Doug at Scan
Chuckpacific
City/Region: SW PDX
Vessel Name: Big Sky
Photos: Big Sky
PostPosted: Wed Jun 06, 2012 11:29 am    Post subject: Reply with quote
I've used Kleen Heat for 9 years with no problems.
There’s only one success – to be able to spend your life in your own way.
2003 CD-22 2002 - 2012
2000 Camano 31 2012
View user's profile Send private message Yahoo Messenger
Da Nag
Vessel Name: Wilbur
Photos: Da Boats
PostPosted: Wed Jun 06, 2012 1:57 pm    Post subject: Re: Fuel Reply with quote
Good point Doug, thanks for the reminder.
However, with the boat being a 2009 Cruiser - I don't think there's much chance of it being anything other than a diesel unless the owner installed something non-standard himself. To my knowledge, only Wallas DU diesel units have been factory installed in C-Dorys.
I'm sure somebody will be along shortly to correct the above if I'm mistaken...
Tux Will, C-Brat Nerd Tux
bridma
City/Region: Comox
Vessel Name: Nomad
Photos: Nomad
PostPosted: Wed Jun 06, 2012 2:58 pm    Post subject: Wallas fuel Reply with quote
Yes, you are right Doug. I should have mentioned in my original post that my Wallas is the 85DU model and my manual says to use Diesel or Kerosene. My question was, can I mix the two if I want to change from one fuel to the other? Or do I have to empty the tank, flush the system, before changing to another fuel type? I presently use Kerosene and everything is working fine. But I have read reports that Diesel gives out a higher heat. Of course, my cautious nature says don't change anything if it's working fine!
Martin.
macmac
PostPosted: Tue Jun 19, 2012 5:23 pm    Post subject: C-Dory stoves Reply with quote
C-Dory did install some model 800/220 stoves. These were intended only for use with kerosene. Diesel will take them out in short order!
Just remember; If your stove has a "D" in it's name, it burns diesel. If it doesn't, it burns kerosene.
macmac
PostPosted: Wed Aug 08, 2012 12:56 pm    Post subject: Changeover Reply with quote
Martin:
Sorry for the late reply! You can mix fuels (kerosene, Klean Heet, diesel #1 or #2) in your tank to change from kerosene or Klean Heat to diesel without emptying the tank, IF it is a diesel Wallas product (95D, 85D, 86D, 87D, 3000D, 3000Dx, 30D, 40D, 22Dt, 30Dt or 40Dt). This assumes the fuels are clean and within their age limits.
Wallas now specifies the use of diesel fuel in all of their products with a "D" designation.
Doug at Scan.
BrentB
City/Region: Greenwood
State or Province: IN
Photos: BrentB
PostPosted: Wed Aug 08, 2012 7:57 pm    Post subject: Reply with quote
useful reference
http://www.scanmarineusa.com/techtalk_FuelCommentsJuly2011.pdf
more tips at
http://www.scanmarineusa.com/techtalk.html
Brent Barrett
Adeline
City/Region: Vancouver
Vessel Name: Adeline
Photos: Adeline
PostPosted: Thu Aug 09, 2012 1:18 am    Post subject: Reply with quote
Thanks for that Doug,
I'm sure I speak for many when I say how grateful I am for your input on this board.
Pete
Rain
City/Region: Oak Harbor
Vessel Name: C-Glory
Photos: C-Glory
PostPosted: Fri Jan 08, 2016 7:14 pm    Post subject: Reply with quote
Let me see if I can resurrect this old thread.
The installer of my Wallas heater/stove filled the fuel tank with "Kerosene K-1" from Ace Hardware. It is also available from Home Depot. It works great, doesn't smell and seems to last almost FOREVER! It is very expensive compared to diesel fuel: >$10.00/gal. compared to <$2.00/gal. It uses so little that I hate to quibble about price, but saving a buck or two here and there is always a good thing! My question is: What could be the down side of using diesel instead of K-1? Smell, performance, required maintenance, other?
"I swear by my life and my love of it that I will never live for the sake of another man, nor ask another man to live for mine."
Ayn Rand, Atlas Shrugged
NORO LIM
City/Region: Olympia
Photos: NORO LIM
PostPosted: Fri Jan 08, 2016 7:19 pm    Post subject: Reply with quote
. . . What could be the down side of using diesel instead of K-1? Smell, performance, required maintenance, other?
I believe the downside might be the ruination of your heater/stove. What model of Wallas do you have? If what you have is a Kerosene ("Paraffin") burner, it won't do well with diesel. Check with the folks at Scan Marine before you try it.
Bill, Formerly on NORO LIM
2001 CD 16, 2001-2006
2006 CC 23, 2006-2014
PostPosted: Fri Jan 08, 2016 8:36 pm    Post subject: Reply with quote
I've been wondering what "paraffin" was. I guess it's kerosene, paraffin in England English. Petrol is gasoline over there.
Thanks for clearing that us. I've been reading/rereading Hiscock's Cruising Under Sail and he uses the therm "paraffin'.
Page generation time: 0.052s (PHP: 69% - SQL: 31%) - SQL queries: 28 - GZIP disabled - Debug on
