Honda / Racor filter interchange?
hughpenk
City/Region: Waterford--Intersection of Hudson River/Chaimplain Canal and Mohawk River Erie Canal
State or Province: NY
Photos: CD 16 (hughpenk)
PostPosted: Fri Dec 21, 2007 10:44 am    Post subject: Reply with quote
A slight diversion here, but related to racor/honda clear bowl fuel filters mouted in the cock-pit against the transom; Is that they tend to take a wack once in a while, like from cockpit chairs and coolers. I have done some searching looking for wire or strapping to protect them from getting banged up but have been unsuccessful and thinking of fabricating. Wondered if anyone has improvised
tsturm
City/Region: Soldotna
Vessel Name: JMR TOO
Photos: JMR-TOO
PostPosted: Fri Dec 21, 2007 10:58 am    Post subject: Reply with quote
I change mine every 100 hrs Racor#S3227(long version) a regular parts store (NAPA etc) will not be able to get these. A marine dealer only $25 bucko's here
warmed up to +10 this morning now if we can just get that sun to come back Mr. Green Beer
westward
C-Dory Year: 1985
Vessel Name: TBD
Photos: Steady Eddy
PostPosted: Fri Dec 21, 2007 11:38 am    Post subject: Reply with quote
I've seen photos on this site of a very neat installation where the person fabricated a shroud to protect the filter assembly. The assembly was mounted on the inside of their transom in the area above the rear drain plug and above the waterline. I think it was a regular contributor, but I can't remember whose boat it was. Very accessible, weather protected, impact protected. Someone else must remember which C-Brat it was... Mike.
flapbreaker
City/Region: Hillsboro
Vessel Name: Playin' Hooky
Photos: Playin' Hooky
PostPosted: Fri Dec 21, 2007 12:36 pm    Post subject: Reply with quote
I changed mine for the first time this fall. I was able to get the filter and bowl off without any trouble, however I had significant trouble getting the bowl off the filter. I could turn the bowl but that's all it would do is turn. It wouldn't come apart. I resorted to cutting the filter in half with a sawzall and using pliers to seperate the two.
PostPosted: Fri Dec 21, 2007 1:00 pm    Post subject: Reply with quote
Mike-
It was DogOnDory Dan. Here's the photo:
Three photos starting HERE.
Merry Christmas!
Joe. Thumbs Up Teeth
dogon dory
Vessel Name: DogOnDory
PostPosted: Fri Dec 21, 2007 1:40 pm    Post subject: Reply with quote
I tend to overbuild stuff. In retrospect, the two pieces of angle are not needed. The rings are easily fabricated with 3/4in aluminum bars stock purcahased at Home Depot our your prefered hardware supplier. I just used a bench vise, a hammer, and a drill for the screw holes. I bent it around a paint can or something. I can't remember what I used.
Holoholo
City/Region: Lincoln
PostPosted: Sun Feb 10, 2008 6:36 pm    Post subject: Fuel Filter For Twins on CD22 Reply with quote
I have tried searching in our library, but have not found if twin 50's (what I have) or 40's require two separate fuel filter/separators or just one adequately sized one? I have a Racor 120R-Rac-01 which shows max flow of 60GPH. According to Racor's general rule of thumb: h.p.x.36 = fuel flow (GPH). Since I have both tanks plumbed to the fuel switch, it goes to the one Racor. My mechanic is recommending that I go directly from one tank to filter to outboard and bypass the fuel switch.
Can someone advise...thank you.
Vern
flapbreaker
PostPosted: Sun Feb 10, 2008 8:21 pm    Post subject: Reply with quote
I'm not sure why your mechanic want's to bypass the fuel switch. I like the choice of burning off one tank first if I need to balance weight ect. Anyway, I have a honda 90 running on one racor rt10 filter. Since the twin setup does not burn any more fuel than a single 90, it would be my uneducated guess that you can use one filter for both engines. Other than redundancy I don't see the point of having two.
PostPosted: Sun Feb 10, 2008 11:23 pm    Post subject: Reply with quote
flapbreaker-
My guess is that your mechanic wants to have a separate fuel tank and filter for each engine so that if the fuel from one becomes contaminated from age or a bad source, the other engine will still run.
With a single filter system, you lose the redundancy of having twins if a single filter or bad tank of gas can disable both engines.
Page generation time: 0.0398s (PHP: 63% - SQL: 37%) - SQL queries: 22 - GZIP disabled - Debug on
