advice on adding house battery and switch
surfbird
City/Region: Los Anchorage
Vessel Name: Turnstone
Photos: Turnstone
PostPosted: Sat Nov 10, 2007 2:25 am    Post subject: advice on adding house battery and switch Reply with quote
I would like to add a house battery and I am confused about the differences between switches that isolate batteries 1 and 2 separately and have a 1+2 setting and those that isolate battery 1 and have a "combined" setting (as shown in the link below).
http://bluesea.com/files/images/products/7650.jpg
Will a 300 ampere unit work or should I get the heavy duty higher amp version?
Do I need a charging relay?
Adeline
City/Region: Vancouver
Vessel Name: Adeline
Photos: Adeline
PostPosted: Sat Nov 10, 2007 3:01 pm    Post subject: Reply with quote
After I added a house battery and an Off,1,2,both switch I decided that I wanted to automate my management. I ended up getting a Blue Seas 7600 and their 5511e which I mounted on an acrylic board along with both positive and negative busbars. Upon starting the engine, once the starting battery has reached a preset voltage the 7600 closes the circuit(combines) and starts charging the house battery. When I kill the motor and the starting battery voltage drops to a preset voltage it is disconnected, preserving it's state of charge. The presets, both combine and disconnect, are selectable. This setup has eliminated the possibility of inadvertently discharging my starting battery.
Pete
PostPosted: Sat Nov 10, 2007 9:49 pm    Post subject: Reply with quote
The 300 amp switches are rated 500 amps intermittant and 700 cranking. This should be fine for any engine you put on a 22.
We also use the Blue Seas combiners on our boats, as well as the battery switch--if you have failure of the combiner, you can always fall back on the switch.
Rob & Karen
City/Region: Franklin
State or Province: TN
Vessel Name: Life of Riley
Photos: Life of Riley
PostPosted: Sat Nov 10, 2007 11:57 pm    Post subject: Reply with quote
I am interested in an ACR for our boat, but I am not clear on how it would interact with our existing 3-bank Guest battery charger, which is hard wired to our two batteries.
The Blue Seas web site says ACR's use mechanical relays controlled by a circuit that senses when a charging source is being applied to either battery. When a charge is being applied, the ACR closes after a short time delay and connects the two batteries.
I understand that this would be good when the alternator is the charging source, but how would this work when the battery charger is the charging source?
Thanks for any assistance.
Rob
PostPosted: Sun Nov 11, 2007 6:21 pm    Post subject: Reply with quote
It turns the relay on, unless you isolate the ARC from the batteries with the battery switches. That is what we did on the Tom Cat.
On the CD 25, I didn't do that, and when running the charger, it does come on. I probably will change the wiring of the 25. But the charger is not used much currently.
Most of these relays have duty cycles in the thousands, if not 100,000 cycles.
mikeporterinmd
State or Province: MD
Vessel Name: Shelly IV
Photos: Shelly-IV
PostPosted: Sun Nov 11, 2007 7:43 pm    Post subject: Reply with quote
Rob
Indeed. The ACR I have can be "switched" and I must remember to
turn off the ACR when the charger is on. Nothing too terrible happens
if you forget, but if the house bank were seriously discharged, you could
cause overly rapid charging. OTOH, I think the ACR has under
voltage detection to avoid big problems.
Anyhow, I have a 110 V relay and plan to make a device that will turn off
the ACR if power is applied to the charger.
Mike
oldgrowth
City/Region: Rochester
Vessel Name: C-Voyager
Photos: C-Voyager
PostPosted: Mon Nov 12, 2007 1:02 am    Post subject: Reply with quote
I have the same setup as Adeline. I did put a LCD indicator light on the dash that lights up when I have my switch on to combine the batteries. The light acts as a reminder so I will not forget to turn the switch off. It is too easy to forget to turn it off, and can lead to the discharge of your starting battery.
When I am charging from a battery charger, I usually hook the charger to the house bank and the ACR will combine the batteries automatically.
When I extended my boat I moved it to under the engine well just above the batteries. Before it was inside the cabin because my batteries were under the port seat. I have had this setup for two years and haven’t had any trouble with it.
________
Page generation time: 0.0334s (PHP: 63% - SQL: 37%) - SQL queries: 20 - GZIP disabled - Debug on
