Alcohol vs Wallas for heating & cooking
PostPosted: Thu Oct 18, 2007 11:40 pm    Post subject: Reply with quote
Just an aside Dr. John - much of the carbon that gets put into a plant comes from CO2 drawn from the air and not from the soil. Much of the N comes from the soil (and N containing fertilizers). When we grow crops which fix N (like soy) we can replenish some of the N by drawing it again from the air. To me, the bigger concerns with bio fuels are:
1) Increasing the cost of food crops and
2) The marginal gain in energy relative to all the energy that went into producing it. There's not a tremendous gain in most cases (except for the farmers who get subsidized for producing the fuel).
DaveS
City/Region: Arlington
Vessel Name: Sea Shift
Photos: Sea Shift
PostPosted: Fri Oct 19, 2007 12:13 am    Post subject: Reply with quote
mikeporterinmd wrote:
Startup is 10 amps or so. If that draw causes your
voltage to get too low, then you might have problems with the Wallace
working correctly.
Mike
You lessen the amount of "draw" on start-up if you raise the lid on your Wallas, thereby eliminating the operation of the fan on start-up. After the stove is heated, lower the lid to then activate the fan and utilize the stove as a heater. (Kinda like sitting and drinking a cup of coffee in the morning before you get too active... Wink )
Dave S.
"Sea Shift"
C-Brat #16
Dora~Jean
City/Region: Simi Valley
Vessel Name: Dora~Jean
Photos: Dora~Jean
PostPosted: Fri Oct 19, 2007 12:15 am    Post subject: Reply with quote
The Wallas 1300 Heater seems to use considerably less startup current. I measured 5.0 amps for 2 min 30 sec then it drops to 0.4 amps during operation, 2 small fans - one in the combustion chamber and one for the forced air output.
I found this in an ad for Klean-Heat, could be talking about either Kerosene or Klean-Heat: "Kerosene and synthetic kerosene (now sold under the name "Klean-Heat") is available at or through most hardware stores and home centers including: Home Depot, Lowe's, American Eagle, Coast to Coast, Ace, True-Value, HWI Do-It Centers, and Wal-Mart." I got mine at the Home Depot in Oxnard, CA, very seasonal though.
Researched several sources on the MSDS (Material Safety Data Sheet), wasn't helpful to learn the chemical composition. It does have a flash point of 142 deg F, which is considerably higher than regular Kerosene (101 deg).
Steve & Carmen
MacGregor 26X 1988-1996
Glaspar Seafair Sedan 18 (2)
StarCraft 19 & 22
Catalina 17 & 22
Crestliner 19
Gratitude
City/Region: Costa Mesa
C-Dory Year: 1992
Vessel Name: C Pelican
Photos: C Pelican
PostPosted: Sat Oct 20, 2007 1:26 pm    Post subject: Alcohol vs Wallas for heating & cooking Reply with quote
Thanks to all for your contributions.
Gratitude is one of the shortest lived emotions on the face of the earth. Make the time to thank others for their help and kindness.
ffheap
City/Region: Hingham
C-Dory Year: 1983
Vessel Name: Inn-The-Water
Photos: Inn-The-Water
PostPosted: Sun Oct 21, 2007 8:20 am    Post subject: Reply with quote
Hi Folks,
Comment on Alcohol Stoves.
There is a big difference between a pressure and a non-pressure alcohol stove.
I had a Perko pressure alcohol stove in a sailboat years ago. I woke up early and in order to heat up the cabin, I lit the pressurized alcohol stove, put a brick on it, opened ports, and went back to sleep. When I awoke later, I didn't notice the flame had gone out. I relit the stove and had a nice boat fire going. I took the firextinguisher out and put the fire out. Immediately, I could not breath. The firextinguisher took all the oxygen out of the air. (I had already moved my wife and kids to the cockpit.) Big lesson.
I now have a single burner Origo non-pressurized stove. It is very safe. All the alcohol is contained within the stove. If the flame goes out,there is no leak. If you use it to much, things get wet, but boating on a small boat is a compromise.
Fred
Fred
dotnmarty
City/Region: Sammamish
Vessel Name: LIZZIE II
Photos: Lizzie
PostPosted: Sun Oct 21, 2007 10:45 am    Post subject: Reply with quote
drjohn71a wrote:
On top of all this, if crop-based fuels were good for the environment and economy, etc., you would be trading being at the mercy of a dozen or so oil magnates to being at the mercy of 2 or 3 large corporations, such as Archers-Daniels-Midland.
Now wait a minute-are you saying "there ain't no free lunch"?
MartyP
Dora~Jean
Photos: Dora~Jean
PostPosted: Sun Oct 21, 2007 11:38 am    Post subject: Reply with quote
Fred, yep, been there done that too! I think the pressured alcohol stoves are responsible for a vast number (if not the majority) of boat fires. I had a double burner (Kenyon I believe) on a 21 ft Reinell cruiser. You pressurized it by hand pumping, then the key was to turn it on and squeak 'just' the right amount of raw alcohol into the round tray under the burner, then turn it off. Then you light the tray, flames shoot up about 1-2 ft, then after the generator got hot you'd turn on the gas and it hopefully stayed lit. Back then curtains were the rage, and yep, those flames caught the curtains on fire one morning, put them out with the fire extinquisher, scared the begeezus out of me. Never owned one since, and to this day I still don't like curtains... Shocked
PostPosted: Sun Oct 21, 2007 2:41 pm    Post subject: Reply with quote
Steve-
I have one of those Kenyon 120 VAC / pressurized alcohol stoves in my Sea Ray.
It's a pretty scary device when you take it apart and see how it's constructed.
The alcohol tank is a copper cylinder with a pump attached and all of this is right under the big electric heating element, separated only by a baffle or two.
Might look like a good bomb design to some!
The former owner of my boat found it so scary he cut the electric supply wire (although he didn't bother to cover either of the new ends of the cut wire!!!)
Kenyon's made a ~million of these stoves, so for the most part they must be usable in a safe mode, but one still has to be very careful! I don't find them available new anymore, although parts are still readily available.
The trend is away from pressurized to non-pressurized alcohol stoves, and to propane as well.
I've got a whole gallon of alcohol under my forward dinette seat. Probably ought to remove it, and place it in my dock box for safety in case the can fails.
Could have enough to use, if needed, in a single small can.
The screw-top metal cans that Berryman B-12 Chemtool Carburetor and Fuel Injector Cleaner comes in are great containers to put solvents such as alcohol, laquer thinner, and paint thinner in to keep small amounts around for cleaning purposes.
They're very strong and safe, much more so than gallon containers.
I keep such things in a baby-blue pained military foot locker on the dock, which also serves as a foot step for boat entry. A 2 inch hole in it provides ventilation so any fumes don't accumulate.
ffheap
C-Dory Year: 1983
PostPosted: Sun Oct 21, 2007 6:05 pm    Post subject: Reply with quote
Joe,
I haven't seen alcohol in metal cans for twenty years.
Fred
PostPosted: Sun Oct 21, 2007 8:31 pm    Post subject: Reply with quote
ffheap wrote:
Joe,
Fred
Fred-
Are you talking about vodka or volatile chemicals? More specifically, are you talking about industrial/comercial uses of alcohol (methyl and ethyl), or ethyl alcohol for human consumption?
True, I haven't seen vodka, gin, rum, whiskey, etc., (you name it), in metal cans, recently, or probably ever!
However, most all volatile/flamable substances such as you buy in hardware, automotive, and similar stores come in metal containers because of Fire Code Laws, which are state mandated, but will vary from state to state.
I have seen some oil based petroeleum paint thinners in plastic bottles, but not alcohol, to my memory.
Gasoline containers can be made of HDPET (polyethehylene), however.
Back when I was teaching, we had gallons of alcohol in metal cans around for the ditto machine before the advent of inexpensive photo copiers. Oops, my age is showing!
PostPosted: Sun Oct 21, 2007 8:49 pm    Post subject: Reply with quote
Hey, Sea Wolf, what's a ditto machine? Remember how you used to cut and scrape the master? Tell me things haven't improved. Now with only a keystroke we can delete our misteaks. Which are underlined for us.
This must be the only users group where one person asks " what's the difference between alcohol and Wallis?" and 5 pages later the discussion is still going on.
PostPosted: Sun Oct 21, 2007 10:26 pm    Post subject: Reply with quote
For what it is worth both methyl and isopropal alcholol are available in plastic containers (see your local drug stores, hardware stores and Wal-mart).
As Dr John, we also own a farm--I suspect that he does the same as we do--we rotate Soy Beans and Corn (as Roger--notes the Soy is nitrogen fixing)--With good crop rotation, and best management practices soil in farms can be sustained--but there is considerable cost to raising crops--various chemicals, have to be spread on the soil as well as insectisides and herbacides. No free lunch here--and if a further comment on the "cost" of biomass fuel is needed in the other thread, I will be happy to make it.
ffheap
C-Dory Year: 1983
PostPosted: Mon Oct 22, 2007 10:43 am    Post subject: Reply with quote
Hi Folks,
I buy industrial alcohol from hardware stores in plastic bottles.
Maybe it still comes in cans, but I haven't seen any lately. I would rather plastic that any rustion metal.
Fred
Not For Hire
City/Region: Cadillac, MI
Vessel Name: Not For Hire
Photos: Not For Hire
PostPosted: Thu Nov 01, 2007 3:51 pm    Post subject: Reply with quote
I promised some pictures and some more info. Well here are some bad pictures, however, you can get double your money back if you complain.
This shows Wallas 1300 installed on cabinet wall under sink. See Dora Jean’s album for good photos and write up by Steve.
In my 22 I mounted 1300 inside cabinet behind helm seat. There is a three inch duct with warm air to white plastic register. The two way stainless pipe is covered in the fiberglass insulation sleeve in these pictures. The water hose tubes never touch the stainless pipe although it may look that way. I put in two pieces of galvanized sheet metal on the underside of the cabinet top where the stainless pipe came close to the top and also where it came close to the many wires I have running below the countertop.
The heater is meant to burn kerosene or paraffin according to the manual and according to Scan Marine’s notes in the manual. I have been using Klean Heat kerosene which is a nice clear kerosene in one gallon bottles. Next year I may switch to the regular Klean Heat. There is no odor with the kerosene. It uses very little fuel.
This is a picture of the Wallas on-off switch on my dash.
Picture of vent at upper forward end of galley where warm air comes out.
I put a plastic surround around the water pump bellows to encourage cool air to flow through the duct further aft. Some air will also enter the galley behind helm seat where the wiring is. This air is only to supply the room air that is heated. The combustion air comes through the outer tube in the double stainless pipe (direct vent style) and the hot exhaust air flows to the outside through the inner tube of that double pipe.
Next to the “cold air return vent” near the deck is a red led light, one of two I installed.
Regards,
Mark
Mark S
Cadillac, Michigan
PostPosted: Thu Nov 01, 2007 4:24 pm    Post subject: Reply with quote
Add to this discussion the dislocation in the price of barley (needed for malt for beer) caused by the corn planting craze for ethanol. Barley plantings that have gone over to corn are a major contributor to the increase in the cost of your beer in 2008, that plus a worldwide hop crisis that have caused the price of hops to increase 2x - 4x.
Page 5 of 6
Page generation time: 0.0606s (PHP: 53% - SQL: 47%) - SQL queries: 28 - GZIP disabled - Debug on
