Roamad
Joined: 20 Jul 2021 Posts: 105 City/Region: Sacramento
C-Dory Year: 1988
C-Dory Model: 22 Classic
Vessel Name: Fika
Photos: Roamad
Posted: Fri Oct 18, 2024 3:09 pm Post subject: New v-berth hatch for 22 Classic? |
I recently acquired a 1983 22 Classic with an old 20” plastic hatch over the v-berth. It is missing both latching arms and the plastic window is badly faded and “crazed”. What do you recommend as a replacement? I want something durable and easy to install. _________________ Now: 1983 22’ C-Dory Classic, 2001 Honda 90hp
Then: 1988 16’ C-Dory Angler, 2008 Mercury 60hp |
Joined: 02 Nov 2003 Posts: 21505 City/Region: Pensacola
Posted: Fri Oct 18, 2024 11:44 pm Post subject: |
Bomar makes a 20" x 20" hatch which should be a direct drop in for the hatch you have. If you want you can also go up in size.
Be sure and remove any wet or delaminated core around the hach cutout. Fill this with thickened (Cabosil) Epoxy between the two deck skins of fiberglass. Then you drill new pilot holes for the screws and put some 4000, boat life life seal, or Dow 795 sealant around the hatch as you screw it down--us masking tape on the deck and edge of the hatch, so it does not have to be cleaned off after the sealant sets up. Take some photos. _________________ Bob Austin
Roamad
C-Dory Year: 1988
Vessel Name: Fika
Photos: Roamad
Posted: Sat Oct 19, 2024 1:09 pm Post subject: |
Thanks for the detailed reply, Bob. I’ll look at Bomar. |
