New v-berth hatch for 22 Classic?
Roamad
City/Region: Sacramento
C-Dory Year: 1988
C-Dory Model: 22 Classic
Vessel Name: Fika
Photos: Roamad
PostPosted: Fri Oct 18, 2024 3:09 pm    Post subject: New v-berth hatch for 22 Classic? Reply with quote
I recently acquired a 1983 22 Classic with an old 20” plastic hatch over the v-berth. It is missing both latching arms and the plastic window is badly faded and “crazed”. What do you recommend as a replacement? I want something durable and easy to install.
Now: 1983 22’ C-Dory Classic, 2001 Honda 90hp
Then: 1988 16’ C-Dory Angler, 2008 Mercury 60hp
PostPosted: Fri Oct 18, 2024 11:44 pm    Post subject: Reply with quote
Bomar makes a 20" x 20" hatch which should be a direct drop in for the hatch you have. If you want you can also go up in size.
Be sure and remove any wet or delaminated core around the hach cutout. Fill this with thickened (Cabosil) Epoxy between the two deck skins of fiberglass. Then you drill new pilot holes for the screws and put some 4000, boat life life seal, or Dow 795 sealant around the hatch as you screw it down--us masking tape on the deck and edge of the hatch, so it does not have to be cleaned off after the sealant sets up. Take some photos.
Roamad
C-Dory Year: 1988
Vessel Name: Fika
Photos: Roamad
PostPosted: Sat Oct 19, 2024 1:09 pm    Post subject: Reply with quote
Thanks for the detailed reply, Bob. I’ll look at Bomar.
Page generation time: 0.0223s (PHP: 61% - SQL: 39%) - SQL queries: 16 - GZIP disabled - Debug on
