Outboard won’t start I only get a single click
ATPNW
City/Region: Covington
Vessel Name: Fellowship
Photos: Fellowship
PostPosted: Sun Jul 16, 2023 12:15 am    Post subject: Outboard won’t start I only get a single click Reply with quote
Was out on the water earlier today trilling. All of a sudden one of my motors (2005 Honda BF50) made an abnormal sound. At the time, I knew it was a familiar sound as it was almost like a higher pitch revving up of something. Within a second it stopped, both my dad and I perplexed couldn’t figure out what just happened. But now everything sounded fine. We fished for another hour trolling. Then headed to the dock with no issue. After tying to the dock, turning off the motor, then getting the trailer I tried to motor up to the trailer. I tried to start that motor but it wouldn’t start. Only a single click. Thinking about it now, the weird sound earlier I’m pretty sure was the starter engaging. My dad said he didn’t touch the key to engage the starter. Things I have tried:
1) kill switch
2) fuel line
3) battery on and charged
4) bench tested starter
5) bench tested solenoid
I still only get a single click. The two things I can think of next are a loose/dirty connection. Or a seized motor, although I really don’t think it’s this of it was running perfectly fine just before. Anything else you all can think of?
I will add that I took off the cowling and when trying to turn the ignition I can see the starter motor spring up and engage the gear, but won’t turn the engine over. I have tried a few times and now the starter motor is stuck in the upright position
ATPNW
Photos: Fellowship
PostPosted: Sun Jul 16, 2023 2:26 am    Post subject: Reply with quote
Update: looks like the motor might be seized. Pulled the spark plugs and tried to turn the flywheel and couldn’t do it. Could not find evidence of water on the plugs nor the cylinder head when I bore scoped them though. This whole ordeal is so bizarre to me. Have no idea where to turn next or what to do.
srbaum
City/Region: Portsmouth
Vessel Name: Osprey
Photos: Osprey
PostPosted: Sun Jul 16, 2023 6:40 am    Post subject: Reply with quote
Atpnw,
Most outboards that have a failure as you have experienced, have catastrophic damage inside of the engine. Usually overhaul of an older powerhead that has internal damage is not cost effective.
Steve Baum
Homeport of Portsmouth, VA
T.R. Bauer
City/Region: Wasilla
Vessel Name: C-Whisperer
PostPosted: Sun Jul 16, 2023 10:25 am    Post subject: Reply with quote
That's terrible to hear it's locked up. And given the circumstances, incredibly odd as you noted. I happen to agree since it was just running. Are you certain it is locked up? It's just crazy. If it is truly locked up, man I'm really sorry Sad
PostPosted: Sun Jul 16, 2023 12:13 pm    Post subject: Reply with quote
Did you check the oil?
Once my engine would not start. It was running fine, but the next time I tried to start it, I got a single click of the starter. It was a bad starter.
T.R. Bauer
PostPosted: Sun Jul 16, 2023 12:32 pm    Post subject: Reply with quote
He reports he can't turn it over by hand with the plugs out. If it were mine, I'd pull off the lower unit and see if the powerhead spins is then free. I'd also make dang sure that starter isn't engaged with the flywheel teeth and is not somehow locking things up. I have never seen an engine with oil in it that was running fine somehow get locked up on the next start and had it actually be the engine. Normally there are kinds of tell tale signs - knocking, grinding, squealing, ticking....all that usual stuff before they give their last gasp on this green earth. Is it possible? Of course, but remotely with extremely low probability.
PostPosted: Sun Jul 16, 2023 12:50 pm    Post subject: Reply with quote
Have you borescoped the cylinders? What does the oil look like? I probably would drain it and look for metal shavings. Maybe even do an oil analysis.
What you describe still makes me thing that there are issues with the starter/system. Was the Bendix gear free of the flywheel when you tried to turn it. Did you use a breaker bar with a socket on the flywheel nut to see if you could rock the flywheel over with more leverage?
To be complete load test the battery (cheap Harbor Freight 12V load tester is adequate for this)
Also just because the starter runs on the bench does not mean it has the power to turn the flywheel. Often it is corrosion on the various terminals for the heavy cable from the battery. Perhaps most neglected, is the ground to the frame of the engine. But it sounds as this is eliminated if the flywheel will not turn by hand. We used to start the 40 and 50 hp outboards with the rope on the flywheel.
Hard to understand why it ran perfectly, no known overheat, no sound of seizing up. Then seemed to seize up and not restart.
ATPNW
Photos: Fellowship
PostPosted: Sun Jul 16, 2023 1:58 pm    Post subject: Reply with quote
I did disengage the bendix from the flywheel, still wouldn’t turn. I inspected the oil fill cap and dipstick but didn’t see any milky residue… The last oil analysis less than 10 hours ago didn’t turn up anything unusual. I’ll try and post pictures of the spark plugs and bore scope pics later today. I’ll remove the lower unit and try the breaker bar. When doing that, I’m assuming I’m going to grab onto the 4 bolts on top of the fly wheel? Maybe with a large crescent wrench?
Thanks for the help and suggestions so far. Had to head east for the day (family emergency). So other than the pictures I’ll post later I probably won’t get much time working on it. But I’ll be sure to keep updating.
Edit: or is this what I’d use to try and turn the flywheel?
https://www.amazon.com/OEMTOOLS-25556-Flexplate-Flywheels-Specialty/dp/B0949M63L8
PostPosted: Sun Jul 16, 2023 3:11 pm    Post subject: Reply with quote
I would go with the strap wrench you linked to. See if it will rock a little. If not then it sounds like tear down vs new engine time....If you can do the rebuild, then not too bad, depending on what damage there is to the block and crank shaft/bearings etc. There is going to be a point of diminishing returns... Unfortunately a seized 50 hp Outbotd motor has little scrap value...
C-Wolfe
Vessel Name: Valhalla
Photos: C-Wolfe
PostPosted: Mon Jul 17, 2023 3:34 am    Post subject: Reply with quote
I have one more thing to add from everything mentioned above before you start opening up the engine. I got a similar thing happen to my 2006 BF50 on a multi day trip, I was very lucky that it solve itself until I could figure out what had happen. One of the magnet came loose from under the flywheel and wedge itself enough to kill the engine, but apparently barely as the engine started right back up and made it home ok. You might want to remove the flywheel before you put too much tork on it just in case. Hope this help
Stephan
Robert H. Wilkinson
City/Region: Port Ryerse
State or Province: ON
Vessel Name: Romakeme IV
Photos: Romakeme IV
PostPosted: Mon Jul 17, 2023 9:13 am    Post subject: Reply with quote
I had a 10hp honda generator once that was working fine when I stopped it then next time it would not turn over. It would stop turning abruptly and you could back it up almost 1 rev then it would stop again. I thought for sure the connecting rod had come off and was jamming it. When a Honda tech told me it could just be carbon I thought he was nuts. He took the head off scraped the carbon off the piston - cleaned it up and put it back together - even reused the head gasket. Worked fine for hundreds of hours after.
I don't think this is your problem - just sharing my experience.
Rob
ATPNW
Photos: Fellowship
PostPosted: Mon Jul 17, 2023 12:43 pm    Post subject: Reply with quote
Thank you all! It would appear C-Wolfe hit the nail on the head! One of the magnets came loose on the flywheel, and got lodged up there. I reinstalled the flywheel minus the broken magnet (for testing purposes only) and was able to hand rotate the engine, phew! While I have you here- I have also posted a picture of my spark plugs from this engine, cylinders 1 and 3 appear to be carbon fouled. I troll a lot, so carbon fouling might be expected? But wouldnt I also expect to see cylinder 2 carbon fouled? Would this point to the valves needing adjusting? Thanks again for everyone's help Smile
C-Wolfe
Photos: C-Wolfe
PostPosted: Mon Jul 17, 2023 1:29 pm    Post subject: Reply with quote
There's mine.
Good call on the magnet! Probably one of the cheapest things which could be happening to cause your problem. Did the flywheel turn in the opposite direction?
The spark plug fouling: may be too rich mixture from the carburetor. You might try adjusting that. Are all spark plugs the same? Too cold a plug for that prolonged idling could be an issue.i. Certainly the plugs need to be switched out, and of course the gaps reset. How is the rest of the ignition system?
ATPNW
Photos: Fellowship
PostPosted: Mon Jul 17, 2023 2:46 pm    Post subject: Reply with quote
C-Wolfe wrote:
There's mine.
Wow, yours took a beating. Did you end up ordering new flywheel or did it continue running like that with one less magnet?
Page generation time: 0.0614s (PHP: 69% - SQL: 31%) - SQL queries: 28 - GZIP disabled - Debug on
