Is my 22 cruiser cabin top cored?
Darkwater
City/Region: Fort Bragg
Photos: Darkwater
PostPosted: Wed Feb 17, 2016 10:56 pm    Post subject: Is my 22 cruiser cabin top cored? Reply with quote
I am looking at fastening a 4-rod fishing rod rack to the ceiling of my 2008 22 cruiser, high top. If the high top is cored I would use screws which would penetrate about 5/8 inch into the top, but I'm not interested in drilling a test hole which would pop outside if the top is not cored!
Anyone have experience with drilling this model year top? Is there variation (cored or not cored) from year to year from different builders? Thanks! Doug
Darkwater Doug
Fort Bragg, Calif
Boat and fishing obsessed...
C-Ray 230DA sold Aug 2013
Retired Dec 2013
2008 C-Dory 22 Cruiser (unnamed) Jun 2014
PostPosted: Thu Feb 18, 2016 12:04 am    Post subject: Reply with quote
The top of my 07 CD22 is not cored. It is maybe 1/2 thick solid FG. It is easy to go all the way through if you are not careful. The PO of my boat had rod holders in the ceiling. These were mounted with bolts drilled through and 5200'd in place. I took the rod holders out, but the bolts are still there. I thought about taking the bolts out, but they are really in there. I'd probably make a mess of the roof getting them out, so I decided to leave them in place.
CDory23
Photos: CDory23
PostPosted: Thu Feb 18, 2016 12:25 am    Post subject: Reply with quote
I bolted my 6 rod holder on to my 03 22 cruiser. I don't remember drilling out any wood but I mounted directly above the cabin door on the angle before the roof becomes flat. I'm not sure if the top is cored or not but imo there isn't enough material to secure screws to for a permanent mount. I put cap nuts on the end of the bolts that are in the cabin and I don't feel it looks bad.
PostPosted: Thu Feb 18, 2016 2:05 am    Post subject: Reply with quote
An alternative to drilling there would be to use a wood piece, and fix it there with some 4200 FastSet, Braced or propped there until it is cured, then drill, tap or screw into that for your rod holder. No possible pointy things sticking through the roof, and no possible leaks. Just a thought.
This method has been tried, used and worked in many situations.
PostPosted: Thu Feb 18, 2016 10:57 am    Post subject: Reply with quote
I mounted my radar antenna directly to the roof, but can't remember if there was any wood in there. I think it was just fiberglass, and not all that thick. Colby
PostPosted: Thu Feb 18, 2016 12:51 pm    Post subject: Reply with quote
I know the roof of our 25 is cored.
http://www.c-brats.com/modules.php?set_albumName=album1192&id=C_Dory_upgrades_2010_004&op=modload&name=gallery&file=index&include=view_photo.php
anchorout
City/Region: Lake Charles
State or Province: LA
Vessel Name: EZ DUZIT
Photos: EZ DUZIT
PostPosted: Thu Feb 18, 2016 1:25 pm    Post subject: roof roof Reply with quote
I removed a search light from the front if my CD22. No core.
PostPosted: Thu Feb 18, 2016 6:21 pm    Post subject: Reply with quote
To the best of my recollection: The very top of the 22, (raised part) is not cored, the lip over the windshield is not cored.
But the side, where the hand rails, and outward is--are cored. The Tom Cat is the opposite. This is for 2006 boats. I would strongly suspect that the hit top is not cored.
Since this fiberglass is fairly thin, you will be far better off, gluing a piece of wood to the inside, and screwing into that. I like either epoxy, or 5200 (I have used both). Hold it in place until it sets up with a dab of hot glue on each end.
Captain Bella
Vessel Name: Irene
Photos: Bucket List
PostPosted: Thu Feb 18, 2016 9:49 pm    Post subject: Reply with quote
My 2006 w/ raised roof was NOT cored. I installed a radar pedestal and made the holes myself.
Jeff
2006 Skagit Orca 27XLC
2006 C Dory 22 Cruiser (re-homed)
breausaw
Vessel Name: Triple J
Photos: Triple J
PostPosted: Fri Feb 19, 2016 11:33 am    Post subject: Reply with quote
You could use an offset bracket attached using the bolts that hold on the top rails, I did something simular on my 25 you can see it in my album under man cave. Aluminum flat stock would work nicely it's easy to work with, and a little imagination.
Boatless for now but looking
Jazzmanic
Photos: C-Dancer
PostPosted: Fri Feb 19, 2016 12:46 pm    Post subject: Reply with quote
This is what I experienced on our 2005 CD Cruiser. The outer area at the back end of the roof was definitely cored as I needed to drill holes on both sides for the radar arch.
Peter & Caryn
Email: pjamero@gmail.com
cbgale
City/Region: Calumet
Vessel Name: Raton
PostPosted: Fri Feb 19, 2016 1:51 pm    Post subject: Reply with quote
2007 22' cruiser high top-Cored where handrails and radar arch bolt on. Not cored on the highest section.
Page generation time: 0.0425s (PHP: 65% - SQL: 35%) - SQL queries: 25 - GZIP disabled - Debug on
