Crab Pot Storage when not in use
redbaronace
City/Region: Puget Sound
PostPosted: Sat Mar 23, 2013 2:28 pm    Post subject: Crab Pot Storage when not in use Reply with quote
Tried to search but did not find the answer I was looking for.
Wanted to be able to store 4 crab pots and the associated gear (Flags, etc) when not in use. I know that many store dingys or other items on the roof, but was hoping to see how the crab traps are stored. Given that the pots are weighted (15lbs each), I need to be sure that I can get them up there safely and not worry about them falling down when underway.
Can some folks post photos of their storage of these.
As an FYI, the pots I will be using do not fold, and are about 2 inches wider, deeper and taller than the danielsons.
PostPosted: Sat Mar 23, 2013 2:34 pm    Post subject: Reply with quote
Here are a couple of photos I saved of some sort of traps (crab, prawn? I don't know how to tell the difference) on a roof rack on a 22 whose name I can't remember [Edited to add: Found it - it's the 22 named "Reel Action"].
Added: Hear is a link to Reel Action's album:
http://www.c-brats.com/modules.php?set_albumName=Prince-Rupert-May-2009&op=modload&name=gallery&file=index&include=view_album.php
I saved the rack photos because I hope to need to use this idea some day Very Happy
T.R. Bauer
City/Region: Wasilla
Vessel Name: C-Whisperer
PostPosted: Sat Mar 23, 2013 3:02 pm    Post subject: Reply with quote
That aluminum rack looks very similar to mine. It took me about a day of screwing around to decide what to build, about an hour to cut the aluminum, and a whole day to get the setting rights on my welder and spool gun to actually make a bead nice enough not to be embarrased by since I used to teach welding for a living a long time ago and my friends would laugh at me. And then about a 1/2 day to weld it all up. About the only difference mine has is a foldable radar tower so it will fit in the garage. Then I made another cooler rack for the transom off a template I had when I made one out of mild steel. Fun stuff in my opinion. The roof will hold far more than you should be putting up there and I'd be reluctant to put any more than 200 pounds on it. And if you do, remember it is up there and drive it nicely as you don't want any stress cracks. I hate fixing fiberglass.....I can never match the damn (sorry) gel coat perfectly........
PostPosted: Sat Mar 23, 2013 3:12 pm    Post subject: Reply with quote
I was just looking through some other albums - whiling away a rain shower indoors - and I happened upon photos of another rack I had not noticed before. This is from the album for the 22 "Princess":
Okay, come on sun so I can get back to my projects!
PostPosted: Sat Mar 23, 2013 9:24 pm    Post subject: Reply with quote
I just store them in "the attic", aka the dinghy and cover it all w/ a bungee spider net while under way.
redbaronace
PostPosted: Sat Mar 23, 2013 10:07 pm    Post subject: Reply with quote
Not sure if this is a joke or not, but wouldnt the sharp metal edges of the crabpots puncture the dingy. Not sure if I want to test this method and find out.
dutch123
City/Region: Prince George
Vessel Name: Reel Action
Photos: Reel Action
PostPosted: Sun Mar 24, 2013 12:42 am    Post subject: Reply with quote
Yes I have had great success with my PVC roof rack. I have doubled it in length since those photos were taken and store as much as my zodiac, two prawn traps, two crab pots,six rubbermaids a scotchman and a five gallon bucket up there and going on four seasons it has never let me down.
The PVC was cut to length and then I cut wooden dowels to fit inside the PVC, I coated the dowels with silicone before inserting then into the PVC then glued the PVC together.
The rack is very strong and has obviously greatly improved my room for storage, it was cheap to build and doesn't have much effect on the hulls tendency to roll as some thought it would.
My dream boat has arrived!
PostPosted: Sun Mar 24, 2013 3:19 am    Post subject: Reply with quote
dutch123 wrote:
Yes I have had great success with my PVC roof rack. I have doubled it in length since those photos were taken and store as much as my zodiac, two prawn traps, two crab pots,six rubbermaids a scotchman and a five gallon bucket up there...
Cool to hear more details on how you made the rack - with the reinforcing dowels. Do you ever use a "floor panel" on it when you are carrying more or different items such as you listed? Or do they always span enough crossbars that between that and tying them down it's enough?
redbaronace
PostPosted: Sun Mar 24, 2013 5:14 am    Post subject: Reply with quote
I like your idea of wood dowels to reinforce the PVC. Can you elaborate on the mechanism by which the PVC attaches to the metal bars above the roof.
dutch123
Photos: Reel Action
PostPosted: Sun Mar 24, 2013 10:29 am    Post subject: Reply with quote
Yes, I used PVC tee fittings cut in half to sandwich the roof rail and a stainless hose clamp on each side to secure it. Before cutting the tee fitting I glued in a flush length of PVC pipe into the two ends of the tee so the tee contacts the rail with its entire length.
Just to clarify I only cut the top of the tee, not the entire fitting in half, with the remaining vertical section of the tee untouched for strength and attachment of the rest of the roof rack.
Sorry if my explanation isn't clear my boat is away in storage or I'd post a pic or two, anyway hope this helps. Thumbs Up
dutch123
Photos: Reel Action
PostPosted: Sun Mar 24, 2013 11:23 am    Post subject: Reply with quote
I haven't used a floor panel of any sort but that would be a great addition for the smaller items for sure. The items I store are large enough that the existing rack works fine as is.
The rack was built as two separate units, this actually increased the racks strength because I have double the tee fittings attached to the rail. Each section consists of a perimeter tube and a 4 way fitting in the racks center and alot of tee fittings and 90's tubing and dowels to finish the rest.
To be honest, this rack was a build as you go kind of project and the sky's the limit with your final design. It would be easy to incorporate a kayak rack or any specific option you wanted to add. It was fun to build and once you just go and buy a bunch of fittings and play around with them things will just come together. Good luck!
PostPosted: Sun Mar 24, 2013 11:24 am    Post subject: Reply with quote
Not a joke. I've done it every season.
PaulNBriannaLynn
City/Region: Fort White
Vessel Name: TBD
Photos: Lorelei
PostPosted: Sun Mar 24, 2013 11:58 am    Post subject: Reply with quote
I don't have a dinghy at this point. I was just going to place a piece of old carpet up there, and stack the pots on the roof and use some ratchet straps to keep them secure. Nothing fancy but it should work fine I think.
PostPosted: Sun Mar 24, 2013 2:28 pm    Post subject: Reply with quote
That will work. I like the bungees, but only when we are out on the water. For towing at freeway speeds, I use ratchet straps.
Jake B
Vessel Name: PLUS 3
Photos: PLUS 3
PostPosted: Sun Mar 24, 2013 11:10 pm    Post subject: Reply with quote
we have a 14' livy that we use as a crab boat, c-dorys seem so nice to do the crab gig out of. crabbing is hard on boats..
Page generation time: 0.0529s (PHP: 64% - SQL: 36%) - SQL queries: 28 - GZIP disabled - Debug on
