mgarr682
Joined: 29 Sep 2012 Posts: 182 City/Region: Asheville
C-Dory Year: 2013
Vessel Name: Glenda Jean
Photos: Glenda Jean
Posted: Sat Jan 12, 2013 5:22 pm Post subject: Padding on deck under the chain? |
I installed the anchor rode on my boat today and I'm wondering how badly that ten inches of deck between the anchor stock and the deck pipe is going to get beat up with the chain laying on it. Any thoughts on how to protect that area over the long term? |
tomherrick Guest
Posted: Sat Jan 12, 2013 5:50 pm Post subject: |
I've not gotten as far as installing these parts on my boat yet, but am thinking that an anchor chain tensioner should do the trick for you. Rather than padding the deck below the chain, it's pulled tight enough not to bounce off the deck. Below is a pic of the first one I found online. A number of variants are available.
Rob & Karen
State or Province: TN
Vessel Name: Life of Riley
Photos: Life of Riley
Posted: Sat Jan 12, 2013 5:52 pm Post subject: |
I use plastic tubing that I slit length wise on my chain. See pic below.
Wandering Sagebrush
Joined: 21 Jan 2005 Posts: 2770 City/Region: Northeast Oregon
Vessel Name: Constant Craving
Photos: Constant Craving
Posted: Sat Jan 12, 2013 6:01 pm Post subject: |
I use a length of split firehose. _________________ "And in the end, it's not the years in your life that count. It's the life in your years." - Abraham Lincoln |
ShellBack
Vessel Name: Thalassa
Photos: Thalassa
Posted: Sat Jan 12, 2013 6:28 pm Post subject: |
Fire hose works great. That is what we use, basic but does the job |
Posted: Sat Jan 12, 2013 11:26 pm Post subject: |
I have the anchor tensioner mentioned by Tom. I have had windlass in the other boats--never been a real problem. If it is, use tubing to cover it--could even be the foam used for insulation of water ;pipes--cheap and soft. I always carry some 1.5" fire hose to use as chafing gear. _________________ Bob Austin
Posted: Sat Jan 12, 2013 11:35 pm Post subject: |
thataway wrote: | <stuff clipped> I always carry some 1.5" fire hose to use as chafing gear. |
I just carry a tube of Desitin. _________________ Roger on Meant to be |
mgarr682
C-Dory Year: 2013
Photos: Glenda Jean
Posted: Sun Jan 13, 2013 9:14 am Post subject: |
thataway wrote: | --could even be the foam used for insulation of water ;pipes--cheap and soft. |
That's a simple idea and I happen to have a section of that in the basement left over from another project. I'll give it a try, thanks! |
bridma
Vessel Name: Nomad
Photos: Nomad
Posted: Sun Jan 13, 2013 11:33 am Post subject: Padding on deck under the chain? |
Look in my album under mods. Easy and inexpensive. Held in place by a couple of dollops of Marine Goop (Canadian Tire).
Martin. |
Posted: Sun Jan 13, 2013 12:19 pm Post subject: Re: Padding on deck under the chain? |
bridma wrote: | Look in my album under mods. Easy and inexpensive. Held in place by a couple of dollops of Marine Goop (Canadian Tire).
Martin. |
Here's the image from Martin's album.
